hello yuo ani prog for eeprom i send the photo for test point
Hello,I am looking for information on how to read and write to a 93c56.My 2002 suzuki gsxr600 has a faulty speedo, it has failed.I bough a replacement speedo however the mileage is incorrect.I am curious how to hook up to the 93c56 chip?and what do I need to read and write the correct data to it?Any help would help me out alot.
So any program for eeproms?What else do I need like a eeprom programmer?I dont want to remvoed the 93c46 from the board.I woudl jsut liek to read from it and write to it.Anyone have any pictures?of this process?and what each leg pin out is?
Maybe this will help you.
Ok thanks guys,any idea how i can hook up to it? to read it?Cable?pins?and what program to use to read it?and write to it?
I do have some of the knowledge.I know it needs 12v to pin 1 and ground to pin2.I believe the quarts crystal has to be jumped.My question is.Do i have to removed the 93c46 chip or can i find a clip that will clip onto the chip leads.and be able to read out all the data.
this is what my pcb looks like
I do have a calculator. I also plan on making a dump file before I burn.The pdf file you have attached is for 97 and 98 gsxr 600.Mine is a 2002.Can nayone confirm if this is stil the same chip??Can anyone tell me if this will do the job?
http://cgi.ebay.com/24Cxx-93Cxx-and-...#ht_2322wt_935
If I dont want to remove th chip from the board can i use a soic dip clip to clip onto the chip and connect to the programmer?or its a must to remove??
