Results 1 to 2 of 2
    Mar 2016
    Default BMW - BOSCH DDE 3.0 - EDC15M - CONNECT ENGINE ECU + IMMO EWS 3 - ON THE BENCH
    HOW TO CONNECT ENGINE ECU ON THE BENCH WITH EWS 3 IMMO SYSTEM
    https://youtu.be/xkUFAljMFdc
    EDC15M + EWS 3 + RING ANTENNA KEY + CAR KEYS
    HOW TO CONNECT BOSCH DDE 3.0 EDC15M AND EWS 3 ON THE BENCH:
    1 - ALL IMMO SOLUTIONS
    2 - IMMO SYSTEM
    3 - BMW OBD PINOUT
    4 - EWS 3 PINOUT
    5 - EDC15M PINOUT
    6 - CONNECT EDC15M ON THE BENCH
    7 - TEST & PROGRAM EDC15M ON THE BENCH
    8 -
    CONNECT EWS 3 ON THE BENCH
    9 - TEST & PROGRAM EWS 3 ON THE BENCH
    10 - CONNECT EDC15M AND EWS 3 ON THE BENCH
    11 - TEST & PROGRAM EDC15M AND EWS 3 ON THE BENCH
    SEE ALSO:
    - CLONE ECU
    Comming soon...
    - ISN CODE CALCULATION
    Comming soon...
    - ECU VIRGIN for RECODE
    Comming soon...
    - CODE/SYNCRO ECU to IMMO EWS 3 SYSTEM ON THE BENCH IMMO OFF by PROGRAMMING just works for SOME ECU REFERENCES like 0281001445 - Comming soon... Just for ECUBYTE SUBSCRIBERS Channel
    - IMMO OFF by IMMO EWS 3 EMULATOR works with ALL ECU REFERENCES - Comming soon... Just for ECUBYTE SUBSCRIBERS Channel
    If it helps!.. give me thanks and reputation!
    Thank you all!
  2. The Following User Says Thank You to Reprogramacoes For This Useful Post:
    triak88 (13th January, 2022)
  3. #2
    kiszka's Avatar
    Aug 2009
    this is an advertisement for your channel on www.youtube.com
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
