Results 1 to 13 of 13
    Jan 2016
    ROMANIA
    Default SIEMENS EMS3132 IMMO OFF
    Hello, I neded help with this ECU, I need immo off, I read and attach AM29F200BB, I try VOLTA solution and cut pin 58, the car do not start, thanks!
    Gammoudi's Avatar
    Dec 2017
    ECUS
    here ..............
  3. The Following User Says Thank You to Gammoudi For This Useful Post:
    mihai cristian (13th January, 2022)
    Jan 2016
    ROMANIA
    Hi, thanks for your help, now I have +12v to the fuel pump, the car still not starting, I do not have engine rpm, the sensor is new, the wire is ok, the car is a Clio 2, 2009 year, can you give me a ideea? Thanks again!
    Gammoudi's Avatar
    Dec 2017
    ECUS
    show me the diagnostic errors ..
  6. The Following User Says Thank You to Gammoudi For This Useful Post:
    Jan 2016
    ROMANIA
    No fault code, in parameter I can not read RPM
  8. #6
    IMM0killer's Avatar
    May 2019
    Sometimes in eeprom , Sometimes in flash
    test and report
    dont forget to cut line 58
  9. The Following 2 Users Say Thank You to IMM0killer For This Useful Post:
    mihai cristian (16th January, 2022), rafal (13th January, 2022)
  10. #7
    Dec 2021
    algeria
    your car dont have off because is can clio 2 only virgin
  11. The Following User Says Thank You to fedji23 For This Useful Post:
  12. #8
    Curitiba, Brazil
    probably the problem is flywheel, some pin broken, or not synchronized with camshaft.
  13. #9
    Jan 2016
    ROMANIA
    Quote Originally Posted by IMM0killer View Post
    test and report
    Is 2009, is on CAN, did you test it on CAN systems? Thanks!
  14. #10
    Jan 2016
    ROMANIA
    Quote Originally Posted by juniorlucival View Post
    I put another plug and wire to the ecu and 2 new sensors, last option for me is the synchronized betwen crank and cam sensors
  15. #11
    Jan 2016
    ROMANIA
    test and report
    In the IC the red led is not blinking, I see it blink only when I try to reprogam old key or new key, but programing procedure is fail every time
  16. #12
    IMM0killer's Avatar
    May 2019
    try using an emulator
  17. #13
    Dec 2018
    Hi. First, check the immo status in the parameters. Because if you do not have the crankshaft speed in the parameters, it is pointless to look for the problem in Immo. Check the sensor voltage, ground and if the signal is coming from the sensor. Maybe there is a problem with the installation or the cube not touching
