    Jan 2019
    Default uch clone problem
    HI,
    I have a laguna 2 with a defective uch, I have managed to save eeprom from ori(old) uch and it was succes 2048 kb size.
    i installed donor uch and paste the ori(old) uch eeprom but car does not start.
    Second option: I virginized donor UCH and tried to rewrite the same old card from old uch with old PIN and ISK
    Car immo On when I put key card in the reader, cannot start What is wrong ? How to rewrite card properly. I have also donor key card.
    Looks like problem is not uch. Check card reader and card.
    Jan 2019
    they are fine. Only unlock button is defective
    Jan 2019
    Now I replaced fine uch but sometimes I introduce my key card and immo flashed rapidly and intermitent, this could be related to key card ? Same simptom with both battery or not interset in key card.
    If I transfer my pcf7946 to another key card it will work radio good or It will just start the car? This problem is intermitent. Also old key card drains battery very fast and not made good contact on battery socket.
    And what was wrong with the car? How did you find that uch is defective? You had to do some diagnostic. Why don't you do it again and see what is going on?
    Nov 2017
    Dobruja
    Quote Originally Posted by Andr33iy98 View Post
    Renault key cards are known for this problem. When bending in the pocket or even water inside. You can swap pcf to a functional card and will be ok
    Post edit. Try sliping a toothpick the same time with the card into the reader to stay firmly and if it will not make problems, unglue the card case and resolder the coil. Often unsolders itself when card is bended.
