Can anyone tell me if this file is good for a stage 2? 2.0 tdi BKD turbo 1756vk? The water is go out of the bottle when it is in full gas. I changed two cylinder heads and an one engine. I don't know what's wrong. Thanks!
you probably need a good mechanic and also an original file to find out where the problem is.
03G906016FM 6179
0281011903
SW 371096
Do you happen to still have the exhaust gas cooling radiator fitted, in case you have it tested.
Egr delete, no cooler egr, intake bmn, exaust bmn 60 mm. it's a software problem or I'm unlucky and the cylinder heads break. Maybe someone will tell me if the software is good to run the car. is the first time I do stage 2 . if I drive nicely I have no problems but if I force it it gives me water out of bottle.
The problem you have is not electronics but a mechanical problem.
You don't have the radiator anymore ok, the water comes out when you pull it more, so you have a compression passage (cracked engine head or head gasket) does the temperature always stay at 90ºc when you pull the car more?
+15 deg of advance on SOI at full load.... no that would never cause a problem.... can't imagine why VW don't do that from the factory...
Awful tune, and yes you could lift a head with that.
yes it stays at 90 degrees C
I'm a beginner in changing file at least stage 2. I hope someone checks my tab to make sure I have no software problems. Thanks
