use protocol 199
Hi .
I have a Sharan 2.0 Tdi 2014 with Adblue ( 140 Ps ) EDC17C46
The Adblue System was bad. Now i decided to delete it.
I have buy an Kess/Ktag kit. And read it with Ktag on bootmode.
First i get an backup.
Then i read it. And put it into Davinci and delete adblue.
Then i put it into winols to make the checksum correction.
It was all ok.
Now i write it with kess.
No fails. No Dtcs. The wire from Adblue Sensor 2 is disconnected.
But car wont start.
I write the original file back und plug the wire in. But no solution.
With Vcds i can read it out. All ok no dtcs.
I have read it with boot and write it with boot.
It is an Edc17C46
03L906018HH
HW: H23
CFFB
7835
0281017094
I have used Protocoll 199
Any ideas?
Thx for your help.
use protocol 199
remix1992 (16th January, 2022)
Hi remix1992
Unfortunately that's the problem with clones, I also killed ECUs and it's frustrating
you can't write boot read with obd
are different reading beetwen boot and obd
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
give me you ecu info maybe i have orginal
It is an Edc17C46
03L906018HH
HW: H23
CFFB
7835
0281017094
sry i have make an double post
Last edited by remix1992; 17th January, 2022 at 12:55 AM. Reason: fail double post
Writ with ktag the full file
remix1992 (22nd January, 2022)
with the files from kess boot mode? i didn read the files or backup files with ktag only with kess.
can anyone check my files?
made with kess
here my files: https://files.fm/u/jsztb7pz3
Probably, DaVinci solution isn't good Everything works fine when you write FULL backup???
works not car doesnt start .
i was at a company that do a new/other file with scr off on the ecu
now it says air mass sensor implausible signal p010100 (167)
do ktag the checksum fix?
why do it with backup file not work?
engine turns but dont go on
if you have ori files(full) , write it in bench with ktag.....
as i can see you still have connection with ecu, that's good.....
other solution i think is to make ecu update with odis.....
Ok I'll explain it from the beginning
First I tried to make a backup with ktag
However, it didn't work.
Then I tried it with kess and noticed that a microsoft tool was missing and it therefore always showed me checksum error
then i installed it and it worked
however, I only made the backup with kess
i didn have odis.
any other solution?
can i get an other file?
must i have the eeprom file from the new one ? or from the old one?
I also have these files. once there is a file (backup)
then I read again and saved the micro
I didn't edit either of them, I put them in a separate folder
then I edited the micro (davinci adblue off--->then winols for checksum correction)
now I only wrote the micro with kess (write button)
everything worked without problems.
I've tested them but the car won't start
the adblue(scr) errors were gone
then i tried to save the control unit again with the backup function. (adblue error back but car won't start)
no errors are stored in the control unit (VCDS)
