Results 1 to 5 of 5
    Nov 2019
    Default Audi A4 Configuration Component Protection
    Hello friends I need your help. I have an Audi A4. I changed the instrument panel and it is all with component protection. Could someone help me remove component protection and configure the new instrument panel? (The original was bad). I have the engine ECU, dashboard and Bcm readings. They are with component protection. Please, I hope your help friends.
    Nov 2019
    Jul 2018
    NZ
    The only possible way to do this is either you have the eeproms of new and old dash or you get vvdi2 or a geko login
    you can use fvdi vvdi2 or geko
    fuzz1's Avatar
    Jul 2019
    Quote Originally Posted by Scooterz View Post
    Would swapping of the eeproms be enough to solve the problem?
