Results 1 to 14 of 14
    Default Zafira Running problems
    I have an intermittant fault with a Vauxhal Zafira 1.8 Z18xe engine,
    Maybe more than one fault but when running from cold get complete loss of power seems to lose it's throttle then all of a sudden revs to about 3000rpm on occassion, then it would clear itself. also generally rough running and when under load revs at about 5000rpm missing as running to lean.
    when looking at data the o2 sensor does not seam to switch between rich/lean as it should but just sits on lean.
    also has the following fault codes stored in ecu.
    P0170 Exhaust lean
    P1555 Throttle position sensor load signal not plausible with engine
    load
    P0301 Cylinder 1 Misfire Detected
    P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    the missfire on no.1 cylinder should proberbly ignored as switched between cylinders as the other day was on Cylinder 4.
    any ideas guys.
    Looks like a leak somewhere in the intake system or a faulty MAF to me.
    Engine is running (dangerously) lean.
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by oldford View Post
    100% agree, nice one oldford
    Maf is common on this,lean condition at idle and rich at cruise,have a look at fuel trim in live data,
    if you fit a new maf either reset adaptions or give car a good run as it will still run rough till this is done
    P1555 load not plausible with throttle is caused by a dirty throttle body,good clean with carb or brake cleaner will sort this
    celje, slovenia
    replace or check o2 senzor
    Thanks for the advice guys I have been researching online and boy oh boy do these zafira's have problems I have come across MAF sensor faults and many people also mentioning to clean out breathers as a hole gets blocked, when cleaning out the throttle body is there a stepper motor that needs cleaning out too.
    Is there a way the Air flow sensor can be tested.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    just get one from the scrappy m8 . if it clears it get a new one from opel only no copy ones there crap ..
    Quote Originally Posted by smirnoff_rules View Post
    Ok mate will do Cheers
    Mar 2009
    Nope.There is no stepper motor.
    spark plugs and ignition coils is in good condition? misfire in cylinder = oxygen in exhaust, lamda sensor voltage drops to 0volts = system to lean
    Jan 2012
    EU
    old message, but today had Zafira with
    fault codes:
    misfire cyl1, misfire cyl2.
    lean mixture
    Engine don't rev over 3000rpm.
    Reason:
    Catalytic converter blocked.
  13. The Following User Says Thank You to Aajii For This Useful Post:
    maddad1 (24th June, 2014)
  14. #13
    May 2018
    opel zafira z18xe have a problem ,go in limp mode and don't want to change gears ,p1895,p1700,p0100,p0700 need help please
  15. #14
    May 2018
    hallo who can help me with a ecu pinout for opel zafira z18xe
