Check the dtc I do not see such a P3501. what's your error description
This error does not exist. Or there is an error in the description. Check the contents of the dtc in car and add an error with the description
nikotina1 (19th January, 2022)
Hello,thanks for answer,Launch is throwing this dtc,pressure on map sensor to high is the description,thanks for help and regards
Hello,anyone has solution?thanks
I have... there is a vacuum leak in the turbo control system.
If have vacuum - low boost, if don't have - high boost...
So, check and fix!
Hello,no leak in vacuum 100%,map sensor is ok,need DTC for manifold high pressure off please,thanks
