Results 1 to 6 of 6
    Oct 2013
    Default Renault Modus 2005 DF048
    Hello,
    i have this error DF048 in UCH of Renault Modus 2005, i read on forum that can solve through dump of power steering ecu 24c16
    can fix it please?
    in attached dump of 24c16
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default modus
    for you
    write and report
    Oct 2013
    i tried but not work... it seems an error of bcm l2cr
    can i make it virgin?
    May 2021
    Dobrý den,
    mám tuto chybu DF048 v UCH Renault Modus 2005, četl jsem na fóru, že může vyřešit výpis z ECU posilovače řízení 24c16,
    může to prosím opravit?
    Aug 2015
    Spain
    Try this file, is virgin and crc OK.
    You should just turn on the ignition and it should autocode.
    Don´t forget thanks buttons if help you
    May 2021
    Hello,
    Thank you
