Results 1 to 12 of 12
    AndriyM6's Avatar
    Nov 2012
    Default 2011 VW JETTA Cluster replacement
    Hello all.
    I replace original instrument cluster in 2011 VW Jetta due to checksum error in immobilizer with used one and program it. Everything works fine and no more checksum error but how I can transfer original mileage from original?
    Prt#: 5K0920972C
    CPU: D70F3427GD
    EEPROM: 95320
    Thank you.
    Sent from my SM-N960U using Tapatalk
    Oct 2014
    Netherlands
    Mileage is stored encrypted with key from flash.
    Read both flash+eeprom and post here if you wish.
    Rgs H2Deetoo
  3. The Following User Says Thank You to H2Deetoo For This Useful Post:
    AndriyM6 (19th January, 2022)
    AndriyM6's Avatar
    Nov 2012
    If somebody can share connections points for this mcu will be really appreciate it.
    I want to try read it with UPA.
    Oct 2014
    Netherlands
    Here you go.
    Rgs H2Deetoo
  6. The Following User Says Thank You to H2Deetoo For This Useful Post:
    AndriyM6 (14th February, 2022)
    AndriyM6's Avatar
    Nov 2012
    Hello. I finally had time to read the data. If anyone is able to help me adjust the milage, I would be very thankfull. Currently it has 123583 miles on it. I need 87538. The flash and eeprom is attached.
    Thank you in advance.
  8. #6
    AndriyM6's Avatar
    Nov 2012
    Can anyone help me please?
  9. #7
    Oct 2014
    Netherlands
    Please try this and report.
    Rgs H2Deetoo
  10. The Following User Says Thank You to H2Deetoo For This Useful Post:
    AndriyM6 (15th February, 2022)
  11. #8
    Smart66's Avatar
    Dec 2020
    What exactly did you use to read NEC? Could you post more pictures while you were doing it? You use this UPA programmer?
  12. #9
    AndriyM6's Avatar
    Nov 2012
    Quote Originally Posted by H2Deetoo View Post
    Rgs H2Deetoo
    Thank you very much for your help. Everything works perfect.
  13. #10
    AndriyM6's Avatar
    Nov 2012
    Quote Originally Posted by Smart66 View Post
    I use UPA-S.
  14. #11
    Smart66's Avatar
    Dec 2020
    Quote Originally Posted by AndriyM6 View Post
    I use UPA-S.
    I can't find exactly the same programmer. Could you post a few pictures or a link?
  15. #12
    AndriyM6's Avatar
    Nov 2012
    https://www.elrasoft.com/uusps.htm
  16. The Following User Says Thank You to AndriyM6 For This Useful Post:
    Smart66 (15th February, 2022)
