Results 1 to 8 of 8
Thread: Ktag problem
    Nov 2016
    Default Ktag problem
    Hi all, I'm looking for a proven software for ktag st 2.25 hw 7.020 because in my program throws at the end of the reading checksum error, has any of you have the tested version?
    If I helped you, click on reputation and thanks.
    If you don't thank for help and give a reputation, you won't get help from me again.
    You use my help at your own risk.
    Jul 2010
    UK
    Common cause for this is C++ libraries not installed.
    Install this from this attachment, restart then try reading again.
    t's been covered a few times on this forum, so consider using the search feature.
    Thanks,
    J.
    Thanks and rep appreciated.
    Nov 2016
    So I saw it about this c + + installed from the site mricrosoft but it did not help
    Jul 2010
    UK
    Install it from that link.
    J.
  5. The Following User Says Thank You to johnnybeast For This Useful Post:
    Stopro92 (20th January, 2022)
  6. #5
    Nov 2016
    Ok, tommorow try. Because I still see on the Internet that people install the first version of ksuite 2.22 I got immediately v2. 53 maybe there is a problem here?
  7. #6
    Jul 2010
    UK
    It'll be the C++ libraries, or maybe a bad driver DLL for that ECU, but more than likely the C++ libraries not the right version, it has to have this version installed to work.
    J.
  8. #7
    Nov 2016
    Ok, try tonight or tomorrow morning and know for yourself.
    Dll files replaced with another file the same was.
  9. #8
    Nov 2016
    I installed this file and everything works! Thank you so much!
  10. The Following User Says Thank You to Stopro92 For This Useful Post:
    johnnybeast (21st January, 2022)
