Results 1 to 4 of 4
    Jun 2013
    EU
    Default Ford Focus 0285001424 2M5T-14B056-BD CLEAR CRASH
    Hello.
    Need tested 100% working crash clear for my own focus.
    Please.... only tested working.
    And one other thing... if i wanted to fake the pretensioners with a resistance how many ohms are the right one?
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Upload photo socket srs unit. I think you can clear crash with autocom via obd or on bench ...
    You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
    If I helped, please, use magic buttons reputation+thanks.
    Best regards.
    Dragon
  3. The Following User Says Thank You to dragon100 For This Useful Post:
    morgano (30th January, 2022)
    VVlad's Avatar
    May 2010
    Ukraine Sumy
    This should work.
    Try and report the result
    Pass PM
  5. The Following User Says Thank You to VVlad For This Useful Post:
  6. #4
    Jun 2013
    EU
    Quote Originally Posted by VVlad View Post
    This should work.
    Pass PM
    Hi, thanks for the effort, that solution i already had tried, keeps giving problem with pretensioners, both on driver and passenger sides, no matter which resistor i attach to the connector, tried 2.2ohm, 2.7ohm, and 3.3ohm always problem with pretensioner circuit.
    Need to test with real unexploded pretensioners to see if they working. But i am having a hard time find correct ones on scrapyard. I wanted to put resistor so airbags work in the meanwhile i find the pretensioners.
    Regards,
  7. The Following User Says Thank You to morgano For This Useful Post:
    VVlad (30th January, 2022)
