Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Dec 2020
    Default W203 200 CDI ECU bricked?
    Hi all,
    I flashed a DPF and EGR off file from a friend with clone KESS to my W203 200 CDI EDC16C2. Flashing appeared to be fine, no errors. But unfortunately now ECU is dead, recovery mode is not working and engine fan keeps spinning.
    I also have clone KTAG.
    I tried searching for correct Bosch BDM pinout, but got confused by different information... Would try to directly solder ribbon cable on PCB if I have correct pins...
    Any idea on how I can recover it?
    Best regards
    al70's Avatar
    Nov 2017
    Éire
    try to read with ktag, protocols, top left corner,, mercedes edc16,
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by elgemo View Post
    Hi all,
    Best regards
    did you read by obd YOUR engine ecu...?
    al70's Avatar
    Nov 2017
    Éire
    Quote Originally Posted by figani View Post
    he used kess clone
    Dec 2020
    Quote Originally Posted by al70 View Post
    I want to try, but I need BDM pinout. I am afraid to break the ECU. Does someone have correct pinout?
    I attached original photo from my ECU.
    Dec 2020
    Yes, we read the original file with clone Kess and then he modified it. Its 1MB bin file.
    rafal's Avatar
    Jul 2010
    UK - PL
    Use ktag + BDM frame and adapter
    All info about connecting in ktag
    All edc16 has same pinout of bdm
    https://youtu.be/7HUQ4OucGQk
    need help
    now my goal is to buy xp-005
    who will help?
  8. The Following User Says Thank You to rafal For This Useful Post:
    elgemo (22nd January, 2022)
  9. #8
    Dec 2020
    Quote Originally Posted by rafal View Post
    You are right, I should use frame. The problem is I need the car for work and If I order BDM frame now takes some days...
    Found this one meanwhile, hope its correct.
    https://www.digital-kaos.co.uk/forum...ght=edc16+ktag
    Will feedback once it was successful...
  10. #9
    rafal's Avatar
    Jul 2010
    UK - PL
    Now is also lesson for you.
    To play with car's....need more tools
    need help
    who will help?
  11. #10
    Dec 2020
    Yes... need more electronics tools...
  12. #11
    Dec 2020
    I will try to read tomorrow using this pinout.
    Can I connect 12V and Ground directly to terminal pins on main connectors of ecu? In this way I could avoid three solderings...
  13. #12
    rafal's Avatar
    Jul 2010
    UK - PL
    I will prefer wait for adapter as kill ECU.
    need help
    who will help?
  14. The Following User Says Thank You to rafal For This Useful Post:
    fuzz1 (6th February, 2022)
  15. #13
    al70's Avatar
    Nov 2017
    Éire
    Those pads don't hold up to much heat, you're gonna end up lifting them, I've been there
  16. The Following User Says Thank You to al70 For This Useful Post:
  17. #14
    Dec 2020
    After some nervous hours, I managed to get the readout, pcb is still fine.
    I have attached one zipe file read with KTAG from status now with all 3 (engine no start), the other zip file contains KESS flash reading only BEFORE I flashed the bad file (engine started).
    What can I do now?
    Can I first try to flash back my original map file into external flash only and check if car starts?
  18. #15
    al70's Avatar
    Nov 2017
    Éire
    Don't write the kess file with ktag, it needs to be changed, someone will help, in the meantime, you should try to find an ori bdm file for your ecu, i think you will need one
  19. The Following 2 Users Say Thank You to al70 For This Useful Post:
    elgemo (24th January, 2022), fuzz1 (6th February, 2022)
