try to read with ktag, protocols, top left corner,, mercedes edc16,
Hi all,
I flashed a DPF and EGR off file from a friend with clone KESS to my W203 200 CDI EDC16C2. Flashing appeared to be fine, no errors. But unfortunately now ECU is dead, recovery mode is not working and engine fan keeps spinning.
I also have clone KTAG.
I tried searching for correct Bosch BDM pinout, but got confused by different information... Would try to directly solder ribbon cable on PCB if I have correct pins...
Any idea on how I can recover it?
Best regards
Use ktag + BDM frame and adapter
All info about connecting in ktag
All edc16 has same pinout of bdm
https://youtu.be/7HUQ4OucGQk
need help
now my goal is to buy xp-005
who will help?
elgemo (22nd January, 2022)
You are right, I should use frame. The problem is I need the car for work and If I order BDM frame now takes some days...
Found this one meanwhile, hope its correct.
https://www.digital-kaos.co.uk/forum...ght=edc16+ktag
Will feedback once it was successful...
Now is also lesson for you.
To play with car's....need more tools
need help
who will help?
I will try to read tomorrow using this pinout.
Can I connect 12V and Ground directly to terminal pins on main connectors of ecu? In this way I could avoid three solderings...
I will prefer wait for adapter as kill ECU.
need help
who will help?
fuzz1 (6th February, 2022)
Those pads don't hold up to much heat, you're gonna end up lifting them, I've been there
After some nervous hours, I managed to get the readout, pcb is still fine.
I have attached one zipe file read with KTAG from status now with all 3 (engine no start), the other zip file contains KESS flash reading only BEFORE I flashed the bad file (engine started).
What can I do now?
Can I first try to flash back my original map file into external flash only and check if car starts?
Don't write the kess file with ktag, it needs to be changed, someone will help, in the meantime, you should try to find an ori bdm file for your ecu, i think you will need one
