Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 63
  1. #46
    Mar 2011
    I ghave the same problem tried all solutions and nothing works...
  2. #47
    have you tried with another computer, you can have bad probe, or a problem pc registry
  3. #48
    cipijoint's Avatar
    this firmware problem is really hardware problem. not software at all.
    clip dont write firmware inside everytime , just check firmware everytime.
    when cannot check firmware , then stuck .
    cannot check firmware because problem hardware in interface.
    only solution is a new CAN PCB board.
    dont talk a lot and nothing
  4. #49
    cipijoint's Avatar
    Also this firmware can be passed, clip will not ask firmware,but also diagnostic will not work ,will stuck after vin recognition when read modules, and will display hardware problem and diagnostic will stop.
    solution is new CAN PCB.
  5. #50
    May 2011
    Quote Originally Posted by Delboy65 View Post
    Hi Guys
    Anyone got the definitive solution for the Clip sensor upgrade problem.
    I'm using Clip v94, when it detects the probe it automatically tries to upgrade the firmware failing at 20%.
    My research here lead me to remove the RSRWIN registration artefacts but to no avail. I found a removal tool (CLIP_registration_remove_v3_d_k.zip ) on this site but it appears to be corrupt. Also noted somebody suggested installing Clip v85 or earlier, but can't find this version on the net.
    The once and for all full solution would be nice.
    hello, friend
    renault can clip now updated to the newest version v110...
    haha
  6. #51
    obdmaster's Avatar
    Never never land
    I had firmware upgrade error and resoldered full pcb.
    Now works 100% no new can board needed
    You need every tool in the book, to do this auto locksmith job.
  7. #52
    cipijoint's Avatar
    And what if you dont have 5 V to ANSC controllers? Just resoldering and 5v appears ? for me not.
  8. #53
    Lithuania
    Quote Originally Posted by obdmaster View Post
    I'm fix clip the same way.
    Have now v111 but trobles with share here any help?
  9. #54
    hello today i conected my clip and software say longtime not make update and need update firmware
    i have version 109 some one know how fix this firmware
  10. #55
    hi good new today for some car work directly no firmaware update for somme car need bypass just star engine and 100% worknig and not get update firmaware update it strangely the probleme is from voltage
    i test master 2003 yesterday say me update
    to day i find solution
    i test espace 4 year 2004 say me update firmware i test with star engine is ok no frimware
    clio 2 X65 2005 is working without star engine
    and clio 3 without start engine
  11. #56
    obdmaster's Avatar
    Never never land
    Mine too was intermittent like that, i thing you will find no matter what car or vehicle voltage fault will return.
    Try resoldering pcb my m8
  12. #57
    didi_du_93000's Avatar
    France Paris
    Hello all we work for repair all problems of our CHINA RENAULT CAN CLIP (including update errors).
    If anyone can help me with electronic knowledge.
    Please see link.
    http://www.digital-kaos.co.uk/forums...ml#post1236841
    Regards.
  13. #58
    no download
  14. #59
    Aug 2011
    for registration clip v118 you have te be connected to renault net with your token
    tanks
  15. #60
    Oct 2008
    Default clip error
    error clip firmware 20%
