Results 1 to 14 of 14
    Jan 2022
    Unhappy Help!! VW52_6Q0 909 605 AJ need clear crash data
    need Help to clear crash data in Caddy Airbag STG!?
    Dec 2021
    Try and report pass in pm
    Jan 2022
    this file not work, i have in eep2 all set to FF....an then is module coding to 000000 and crash data already in memory.
    thanks for helping
    goblincalm's Avatar
    Dec 2017
    Default VW52_6Q0 909 605 AJ
    Test and report back.
    Jan 2022
    is the same, after write is coding 000000 and fault code....crash data stored.
    the unit has 2 eeproms you mean eep2 , right ?
    Dec 2021
    Try write only first eprom
    You clean up the dump,
    coding: 23095
    PASS=PM
  8. The Following User Says Thank You to bolonc For This Useful Post:
    cello16 (27th January, 2022)
    Jan 2022
    this file works, coding passed and no errors ! thanks bolonc....
  10. #9
    Jan 2022
    New problem, airbag Control lamp is blinking no fault code in memory? In autoscan is airbag Red....
  11. #10
    Jan 2022
    still need a dump for 6Q0 909 605 AJ , coding is 23095 ...
  12. #11
    Quote Originally Posted by cello16 View Post
    Eeprom2 must be written back to the original.
  13. #12
    Jan 2022
    Good morning, I have written the ori. eep2 in module and installed...airbag lamp is blinking. 0 errors.....mmh?
  14. #13
    Sorry, maybe I changed too much...
    Try this file
  15. #14
    Sep 2018
    please, pas on PM
    100% working
