Results 1 to 4 of 4
    Mar 2017
    Default fix flash edc16c31 525d e61 0281012190 sw 1037390905
    I need help fixing flash after write failure
    Hw0281012190
    sw 1037390905
    Up sw 07812334
    Dec 2018
    Where have you been so far? Mar 2017 and 4 Posts? As already that's more of the description. What did you upload? And what is the error? Car start? Is it not already start? Ecu connects etc.
    Mar 2017
    when uploading Flash obd kees v2, there was a communication error, the car does not want to start, then it was impossible to upload it. INPA does not see DDE. After removing the ECU, the BDM KTAG reading returns a checksum error. I need to fix my flash and upload it Ktag. I don't write much first I try to read and search
    Mar 2017
    problem solved, DDE was damaged.
    Full BDM
