Results 1 to 14 of 14
    droidwayne65's Avatar
    Aug 2015
    North America
    Default Help with a 2004 Volvo XC90 CEM
    I have this CEM, without a working key, where about the last half of the Flash was erased. I was able to get the original's VIN, key and sync info, with which I modded the donor CEM file then added a key. I'm not very familiar with Volvo CEM, so could someone who is check this file and tell me what else needs to be done? Enclosed are the original and modded files. Thanks.
    <---- Coin of the Realm.
    Aug 2015
    North America
    Well, I tried the file as-is and the car would not turn on, except for the "check engine" light on the dash. Tried again after altering just the VIN, with the same result. This leads me to suspect it's a checksum error but, for the life of me, I can't find any data that looks like a checksum after each block. So does anyone know where to look for checksums or of software that can do the calculation?
    MartiLer's Avatar
    Dec 2016
    everything is done by hand. first you need to show the original damaged 28f400 dump and the ECM dump. what you posted in the first post is not useful to you. And don't forget the config. Other people's dumps are bad helpers in Volvo.
  4. The Following User Says Thank You to MartiLer For This Useful Post:
    taxo1965 (4th February, 2022)
    Aug 2015
    North America
    Quote Originally Posted by MartiLer View Post
    These are the original files plus the one I've been trying to mod.
    MartiLer's Avatar
    Dec 2016
    try replacing flash. your intel is dead. and you need to work with this CEM using BDM contacts.
  7. The Following User Says Thank You to MartiLer For This Useful Post:
    droidwayne65 (26th January, 2022)
  8. #6
    Aug 2015
    North America
    I realized that and swapped it out. I am now the third person to work with this car but I just managed to track down the original locksmith who worked on it. He sent me his first read but he says the car went dead after writing it. I'm not sure whether the file is bad or maybe the flash went bad. Could you please take a look at it?
  9. #7
    MartiLer's Avatar
    Dec 2016
    this dump also has errors.
  10. The Following User Says Thank You to MartiLer For This Useful Post:
  11. #8
    Aug 2015
    North America
    Ahhh, K. Are you able to repair them?
  12. #9
    Aug 2015
    North America
    With which programmer? I've identified the BDM contacts but I've never tried to use them. I usually just remove and reinstall the flash.
  13. #10
    Jun 2013
    Quote Originally Posted by droidwayne65 View Post
    28f400
    J-tag Smok
  14. The Following User Says Thank You to Weasel3 For This Useful Post:
    droidwayne65 (27th January, 2022)
  15. #11
    28F400 wery sensitiwe hot air see my post after desoldering flash is not working
    https://www.digital-kaos.co.uk/forums/showthread.php/652451-CEM-VOLVO-S60?highlight=28f400
  16. #12
  17. The Following User Says Thank You to janusz21 For This Useful Post:
  18. #13
    MartiLer's Avatar
    Dec 2016
    I use a homemade programmer. today it is the cheapest and highest quality programmer in the world. its cost is only 20 euro. And anyone can easily assemble it.
  19. The Following 5 Users Say Thank You to MartiLer For This Useful Post:
    alex_r_2001 (28th January, 2022), droidwayne65 (28th January, 2022), Faraday (2nd February, 2022), janusz21 (28th January, 2022), taxo1965 (4th February, 2022)
  20. #14
    Aug 2015
    North America
    Thanks fellas, and a special one to @MartiLer. This has been an education. I've been messing with these units for years and I guess it's just been my good fortune to have never run into a problem quite like this. I think I've used the flash removal method for the last time.
  21. The Following User Says Thank You to droidwayne65 For This Useful Post:
    MartiLer (28th January, 2022)
