Hi, this is all that I have found after an hard search on google...
It is about a Stilo Body Computer (that should be the same, or very similar, to alfa 147), and the topic was about adding the cruise control...
NQS Configuration. #44
Bit 0 = 0/1 means gas discharge lamp disabled/enabled
Bit 1 = 0/1 means over-speed warning disabled/enabled
Bit 2 = 0/1 means ODO units change disabled/enabled
Bit 3 = 0/1 means auto-lamps not fitted/fitted
Bit 4 = 0/1 means Cruise control absent/present
Bit 5 = 0/1 means transmission type manual/auto
Bit 6 = 0/1 means oil information request/not request
Bit 7 not used / reserved
NQS configuration is about the dashboard node. Looking at your dump, it looks like ODOmeter units are changed (and it looks ok, they should be miles...), and that auto-lamps are fitted. Can you confirm this?
I need more extended information on proxy file, in order to reprogram the NFR (brakes/abs/asr/vdc) configuration inside the body computer and NOT get the "wrong CAN configuration" error from ABS ECU once fitted. The car is a 2001 Alfa 147.
Furthermore, I guess I should install the steering sensor (which is also connected to CAN), and so properly code it in the same proxy file inside the body computer...
Can someone help me...?
