Fiat BSI ,hacks ,configuration request - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 36 of 36
  1. #31
    EARTH
    880
    Downloads
    75
    Uploads
    Default CARPROG
    i used CARPROG , works fine !
  2. #32
    28
    Downloads
    89
    Uploads
    Colleagues when I wanted to swap the Fiat Stilo Body Computer where HC912DG128 what is the need to do everything ? Probably not suffice Play HC912DG128. Immo even know code to learn the keys ?
  3. #33
    Member Karizmo's Avatar
    Downloads
    53
    Uploads
    Quote Originally Posted by wintesla[SR] View Post
    Only solution for your,,hack,, is to take LEONARDO and make change and every time read eeprom.
    But..............
    Leonardo not make like you read or some tell you.
    I hear to much thing , and when finaly i get leonardo ...............
    To much money for .............nothing.
    And in 70% of car update coming.
    All diag make config in new type body.
    In older type cant make config like you want.
    What is "Leonardo" and wher i can find it !
  4. #34
    cantabria, north spain
    35
    Downloads
    27
    Uploads
    Anybody knows how to change proxy to make my cars instrument go back to count revs/ km as a diesel?
    I changed instruments cluster in my jtd to a gasoline and proxy alignment worked fine, but now I am trying to put a diesel one and I can not make it count properly. I get ASR error as well, but I think I can fix that with the solution above.
  5. #35
    35
    Downloads
    27
    Uploads
    Hello beppe, could I have proxy data for a stilo multijet with abs diesel115?
  6. #36
    Dec 2015
    Minsk, Belarus
    11
    Downloads
    Uploads
    Hello guys!
    I have Alfa GT 2006 year and i change VDS to ABS only.
    But my dashboard show ASR and VDS error. Is it possible write somewhere info about ABS only?
