Results 1 to 2 of 2
    Dec 2020
    Default After programming the ECU is dead BOSH ME7.5 Audi TT
    Hello,
    I managed to kill the ECU yesterday after inserting the map.
    The car Audi TT 8n
    Bosh ME 7.5 engine controller
    I read the map using MPPS V18 then deleted one DTC and re-uploaded.
    At the very end I made one mistake when Mpps told me to turn the ignition off for 10s and turn it on for 10s, and then click "OK".
    I just turned off the ignition for 10s and clicked "OK"
    Mpps showed that flashing the ECU is complete.
    The car fired once and then I did not start.
    No engine ECU communication after checking.
    I took the ECU out of the car and read the driver on the table in Boot Mode using MPPS V18.
    What should I do now to make the engine ECU work properly?
    calibracbr's Avatar
    Aug 2015
    Moon
    Write it in boot mode
