Results 1 to 9 of 9
    Jan 2022
    Default Smart Fortwo 451 Sam pinout Xprog-m mc9s12b128 3L80R
    Hi, I am trying to connect Xprog-m to my donor sam (read my original sam mcu ok). However I am getting a "bootloader initializing cant access bdm" error with the same pinout (see photo).
    Can someone help. do i need to lift a pin? or is there an alternative pinout?
    Thanks!!
    https://ibb.co/Zf9w7TS
    https://ibb.co/N1Hm5JN
    Jan 2022
    good news! it turns out it was a secured chip and just needed the addtion of ETAL as per pinout found on the web.
    I have now found that my original sam dump is 4kb and my donar chip dump is 2kb.
    can anyone help me transfer the 4kb good dump data to fit the 2kb chip dump?
    Jan 2022
    Can anyone help convert this dump to 2kb?
    Jan 2022
    These are my attempts transfering to a 1k file. Can someone have a look and see if either look ok?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by gurusi View Post
    Thanks!!
    you have soldered 4 Lines...?
    right...?
    Jan 2022
    Quote Originally Posted by figani View Post
    right...?
    correct ground, reset, vcc and extal (verify errors without extal). chip reads and writes and verify without issues.
    As my original sam chip dump is 2kb and replacement 1kb having troubles converting...
    does the dump look good?
    figani's Avatar
    Feb 2018
    It's secured...
    Don't understand right what are you doing...
    You know how to read write secured MCU...?
    Check manual of xprog...
  8. The Following User Says Thank You to figani For This Useful Post:
    gurusi (28th January, 2022)
    Jan 2022
    It's secured...
    Thanks for the help, yes i realise it is secured and now have the data (see second post above). Maybe i should have posted a new thread request to avoid confusion
    now ive got the data from my original SAM (4kb file). i need to put it on my donor SAM which requires a 2kb file. I need help converting it.
    Attached again. Any help converting it would be much appreciated
  10. #9
    Oct 2018
    Hi, did you figure out the pinouts for this? i saw the picture but you cannot see what connections were made in what colour to the xprog unit, or a description of what wire you have connected to the sam, for exaple the white wire soldered to the sam unit connects to a bluse wirw twisted, what connection is that to the chip?
    I hope that makes sense.. thanks
