Results 1 to 4 of 4
    Oct 2020
    Bulgaria
    Default Peugeot Parnet 2 edc17c10 DPF OFF
    Hello, I need help.
    I turned off the DPF with the DPF Remover 2017.05 program, no error messages are displayed except for the fan. The car starts running, if you drive it on high loads there is no problem and at the moment when the car stops motionless you hear a sound signal and the car has no power. Very strange
    HW: 9666077280
    SW: 9666729580
    SW upg.: 9691584280
    Read with k-tag
    Johnsy1998's Avatar
    Oct 2019
    United Kingdom
    Likely bad solution... Try manual solution
    Don't forget too THANKS + REP
  3. The Following User Says Thank You to Johnsy1998 For This Useful Post:
    Acidhack (27th January, 2022)
    Oct 2020
    Bulgaria
    Need pasword.?!??
    Oct 2020
    Bulgaria
    The saga continues, no mistakes are made except for the cooling fans. The car starts if you leave immediately there is no problem, but if you stop instead you hear a signal and the car loses power. There is no mistake again ......... Someone give an idea
