Results 1 to 8 of 8
Hybrid View
    Jan 2020
    Default VELAR BCM CLONING.
    please I need your help. Am trying to clone range rover BCM. Which I read and verify both spc5746/5748, and write into the used BCM and verify and yet won't on ignition. I read and write both 46/48. When I read the car with jlr pathfinder software the new used BCM still have it old Vin number so I ask where is the car reading the Vin from the BCM, which ic has the information. Thanks.
    Sep 2020
    which bcm number ?
    Jan 2020
    Quote Originally Posted by bmwspec View Post
    which bcm number ?
    JPLA-14F041-BG
    catalinos2001's Avatar
    Oct 2016
    Germany
    Please help with Range Rover Evlar with water damage , i found this ECU total damage and i found in Greece same ECU , my question if i buy this ecu i must take also the starter kit ? Immo , Keys.....
    Best regrads
    Mexaniks's Avatar
    Mar 2013
    UA ODESSA
    Quote Originally Posted by catalinos2001 View Post
    Best regrads
    Hello. I may disappoint you - but this is not an engine control unit. This is the head unit
    Oct 2016
    Germany
    Quote Originally Posted by Mexaniks View Post
    Ok , my mistake that i found with complet damage !
    Europe
    can u tell me how did you read it?
    Xprog or vvdiprog? or any other?
    thx
    Europe
    Quote Originally Posted by vilali View Post
    thx
