and P0135 DTC OFF please thanks
dont forget click thanks
Akos421 (28th January, 2022)
here you go ,temperature sensor and diferential sensor must be disconnected
Akos421 (1st March, 2022)
You need to do the checksum on the file
good morning,
this car came to me with already dpf made by another garage...
The car turns on the radiator fan every now and then, minimum adjust.
can anyone check me if this egr dpf is a good job ??
thank you in advance....
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
Akos421 (5th June, 2022)
I compared the file and it's an ads solution .... strange that it didn't have any problems ....
neasuno manages to give me an eye ..... my radiator fan starts when the engine starts to be its 70/80 degrees ..... I read around that the problem is in the file precisely in the sensor area dpf probes .... but without damos / ols i can't
