Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Apr 2016
    Default Opel Astra J AcDelco E83 reset(virgin)
    Hello,
    Looking for help to reset(virgin) Opel Astra J AcDelco E83 12638807 ecu.
    rafal's Avatar
    Jul 2010
    UK - PL
    use pin 0587................for reset
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following 2 Users Say Thank You to rafal For This Useful Post:
    miroopel (29th January, 2022), MrQuestion (29th January, 2022)
    Apr 2016
    Do not have tool for reset. Not possible to reset by file?
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by MrQuestion View Post
    no tools - change job or invest
    need help
    who will help?
  6. The Following 2 Users Say Thank You to rafal For This Useful Post:
    avital (31st January, 2022), miroopel (29th January, 2022)
  7. #5
    Apr 2016
    Thank you Rafal
    Quote Originally Posted by rafal View Post
  8. #6
    filutek's Avatar
    Aug 2009
    Silesia
    ECU logged out, what do you need this for?
    I can add after files.ECU-BCM
    The worst part is that someone doesn't know what to do with it .... sorry
    IMMODATA ACDelco EXX<=>BCM / BCM MERIVA B REPAIR. ALL CRC-I see it ...
  9. The Following 3 Users Say Thank You to filutek For This Useful Post:
    Bllinda (30th January, 2022), miroopel (30th January, 2022), MrQuestion (30th January, 2022)
  10. #7
    Apr 2016
    Quote Originally Posted by filutek View Post
    The file you have made is it virgin? I still see same vin and same pin code in the file. Is it tested solution?
  11. #8
    Apr 2016
    Can some one tell me which tools or software are needed to reset e83 ecu in the car.
    I have tech2 sps programing and gds2, but did not find reset function.
  12. #9
    filutek's Avatar
    Aug 2009
    Silesia
    This is the file after preparation for disassembly.You need a pin from the car and globalTIS online.Passthru.
    Do you have the original BCM reading from your car?
    Is this ECU from your car or bought?
    I can add ...........
  13. #10
    Apr 2016
    This ecu file is from another used ecu. Original ecu from car is totally dead.
    Here is file from BCM. Can you match Ecu and bcm?
  14. #11
    filutek's Avatar
    Aug 2009
    Silesia
    Yes.
  15. #12
    Apr 2016
    Perfect
    Yes.
  16. #13
    filutek's Avatar
    Aug 2009
    Silesia
    Synchro ...... write ECU
  17. The Following User Says Thank You to filutek For This Useful Post:
    MrQuestion (31st January, 2022)
  18. #14
    filutek's Avatar
    Aug 2009
    Silesia
    Done .........................
  19. #15
    Dec 2010
    HI.
    i have the same problem did you solve it please
