Results 1 to 7 of 7
    Feb 2022
    Default VW UP ABS long coding
    Hello , i have a problem with my VW Up
    The ABS code ist lost and needed to program again
    this is a long code
    a tried already different codes that i finf online but with no result
    VW UP
    2013
    Petrol
    Vin number : WVWZZZAAZED032980
    can anyone help me with the right code?
    Apr 2021
    Identification data from your ABS please. It needs sw part number first, and then some info about your vehicle.
    Or a scan, and like 80% of info is covered.
    //edit: I think you post accidentally landed in the wrong section it's you lucky day I discovered it here as it was on main page
    Feb 2022
    ok thanks , i will get this info monday
    Feb 2022
    Hello
    My Abs module number 1S0 614 517 E
    Motor Management number 04C 907 309 N
    With Delphi Technologies :
    Fault Codes : U101700 , U012100 , U015500
    With CDP PRO diagnostics
    Fault Code U101300
    Need module coding
    i tried some long codes i found online , did not work
    with the CDP PRO diagnostics i can self put code in if i have the right code
    is this enough info ?
    Apr 2021
    Quote Originally Posted by Patrick1974 View Post
    Hello
    Fault Code U101300
    Need module coding
    Please confirm that 1S0 614 517 E is the SW part number read from diagnostics (not hardware part number from diagnostics or sticker on pump or anything else). It is always recommended to post a scan, or parts of it, as they make things totally clear.
    So what else it needs now is:
    - left hand drive or right hand drive?
    - does it have engine start stop?
    - is it manual or automatic transmission?
    - does it have tire pressure monitoring?
    - does it have (or do you want) hill hold control?
    - does it have front assist (radar)?
    - does it have a traction control button (button to switch of ASR)
    - does it have a mechanical steering or a column electrohydraulic steering (so called CEPS)
    Half of that could also be answered by posting a full scan.
    Feb 2022
    eft hand drive
    no start stop
    manual
    no tire pressure monitoring
    no hill hold control
    no radar
    no traction control
    1S0 614 517 E is the number on the part
    in the diagnostic see no number on from the faults
    Nov 2020
    Radio code PEUGEOT CLARION PU-9990A
    SERIAL No *C 70000004343
