Results 1 to 9 of 9
    Jan 2019
    Default Zedbull can programm a id 48 chip for skoda fabia 1.4 from 2001?
    So my tittle said, Zedbull can programm a id 48 chip for skoda fabia 1.4 from 2001?
    Programming means precode ? Or they are different things ?
    Dec 2018
    Hi. Generally programming. And precoding are two different things. Programming consists in reading the file. And key programming for it. Pre-coding is to prepare the transponder for car programming. Using a dyadnostic tester. And this skoda interests you. You need a pin car. And 3 minutes and you have the key. Best regards
    Jan 2019
    I have only vcds, zedbull can programm this chip ? I have the pin number from dump of original car immo.
    Nov 2017
    Dobruja
    I suppose you bought the id48 already precoded, even they call it blank. Is blank because was never written to a car.
    So enter with vcds at 17 - Instruments and add new key using your pin code from the car. Scan it with zedbull and see if is Unlocked and give it a go.
    If you already have a key, you must ad both old and new when programming. Search on rostech site how to program, or youtube.
  5. The Following 2 Users Say Thank You to volodin69 For This Useful Post:
    fuzz1 (12th February, 2022), Mario6 (6th February, 2022)
    Jan 2019
    So I can do all job with vcds If i know pin code ?
    Dec 2018
    Quote Originally Posted by Andr33iy98 View Post
    Exactly. Vcds is very good for this.
    Jan 2019
    But I do not understand how to program a new blank chip id48 for my car with vcds ?
    Dec 2018
    It seems to me that the topic has been exhausted. A colleague of the post above described you clearly. Or take a look at the video on youtube
  10. The Following User Says Thank You to elektronik325 For This Useful Post:
    volodin69 (9th February, 2022)
  11. #9
    Nov 2017
    Dobruja
    My friend. Is easy job. All of us started to achieve knowledge by doing and breaking things on our own. If i write you a full topic for that, i will be banned for polute the site. Search on DK forum (plenty of similar descriptions) or on google how to do it and learn by yourself this basic thing. If i will teach you a poem, and you repeat after me you will not understand the sense of it, because you did not struggled to read it by yourself. Simple as life is. Good luck
    Post Edit: a specific user here sent me a PM without connecting the brain to the hands before writting.
    I RECOMMEND HIM THE "SEARCH" BUTTON, INSTEAD OF HAVING FALSE EXPECTATIONS FOR BEING TOO LAZY TO SCROLL THE FORUM.
