Results 1 to 5 of 5
    Jun 2017
    Default MIB2 connecting the UART
    hi
    I connected the UART TTL adapter to RX/TX pins units delphi. I get log stream which I don't know how to stop so what can I do next?
    Could you help me?
    Polska
    Hello, I connect to the topic I have the same. do you have any solution
    I have a solution for another unit but with Delphi MIB-HS 8W0035193 it does not work, I guess
    Jun 2017
    hi
    I know that to connect with unit Delphi is possible by connect emmc but I don't know which device I have to use and how to connect
    Aug 2021
    Mogilev
    Connect FT232RL - TTL
  5. The Following User Says Thank You to artsem48 For This Useful Post:
    lwd11 (15th September, 2022)
    Jan 2022
    Hi Mally39! I break my mhconfig and my mib is working partially. I've reading could be repaired using UART. Could you help me?
    Thanks in advance!!
