Results 1 to 10 of 10
    Nov 2018
    P L
    Default I cant download file from one topic, thread
    Hello guys. I can't download the file in the topic I set up. I asked for a file, my friend added to the topic and I can't download it. an information window opens when you try to download it;
    You are not logged in or you do not have permission to access this page. This could be due to one of several reasons:
    1. You are not logged in. Fill in the form at the bottom of this page and try again.
    2. You may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    3. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
    The administrator may have required you to register before you can view this page.
    it only affects this file. I use the forum normally all the time, add and download various files. at the moment, I can download various other files from other themes, just not this one. why ?? where is the problem ??
    I have had an account for several years, I am logged in correctly. I do not know what's going on ????
    Nov 2018
    P L
    halllooooooo !!!!!!!!!!!!!!!!!!!!!!!!!!
    is any of the forum moderators here to explain this situation ???????????
    Apr 2021
    Depending on which post or file you are talking about and in which section it is located (you did not tell here, so I wonder how anyone should be able to correctly answer that question at all), my guess is: reason number 2) will be the problem.
    Even though it sounds a little weird that opening a topic in that particular section is possible, but downloading files is not. So about which topic are you talking, maybe someone else could try to see if it only affects you or if it is a general issue.
    Nov 2018
    P L
    the next day everything ok. file downloaded without any problems, as it usually is. I have no idea where this relationship comes from. the weird thing is that this is the topic that i personally started. hopefully such situations would not happen more times.
    Jun 2023
    Hello,
    I am having the same issue. Getting a login in screen when trying to download. It takes me back to the login screen. Can someone pls help? Thanks,
    Aug 2009
    it appears quite common with a google search
    Aug 2015
    Spain
    If this type of problem happens, it is often solved by using another type of browser, when it has happened to me many times I have used Microsoft Edge and voila, it works
  8. The Following User Says Thank You to Josue For This Useful Post:
    hevic (24th September, 2024)
  9. #8
    Jul 2024
    USA
    Quote Originally Posted by yarowsc View Post
    Hello,
    I think you're logged in and can download other files, this particular file might have restricted access. Make sure you’re properly logged in and that your account has the necessary permissions to access this file. If you’re still having trouble, it’s a good idea to contact the forum administrator to check if there are any specific restrictions or settings on that file.
  10. The Following User Says Thank You to dinadely For This Useful Post:
  11. #9
    Jul 2024
    SPAIN
    Hello, I have the same problem.
    There are a number of post for downloads?
    Thanks in advance
  12. #10
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    try reading the rules !!!
