Results 1 to 8 of 8
    Feb 2022
    Default Help needed CLIO 3 DF002 Fault
    Can anyone repair this file please
    Coming up with DF002 Fault
    No power steering
    Original ecu
    Thank You!
    reproteq's Avatar
    en algún lugar de España
    put here dtc pxxxx not renault code fault
  3. The Following User Says Thank You to reproteq For This Useful Post:
    TomD11 (7th February, 2022)
    Feb 2022
    Autel only gives me DF002
    Renolink gives me code 5608
    Thanls
    reproteq's Avatar
    your file only 1kB is very very low , this is eprom file? or flash or mcu ?
    you have a mistake?
    0 thanks
    uff
  6. The Following User Says Thank You to reproteq For This Useful Post:
    Feb 2022
    Sorry new to this trying to get eprom dump with Renolink not sure if it’s possible?
    thank you
  8. #6
    reproteq's Avatar
    no mate no , dtc not in eprom
  9. The Following 2 Users Say Thank You to reproteq For This Useful Post:
    budata (7th February, 2022), TomD11 (7th February, 2022)
  10. #7
    Feb 2022
    Any advice how I can do it with renolink at all? Or how to fix it
  11. #8
    reproteq's Avatar
    first post here ecu image for see version after need take flash tool for read mcu or flash .
    when you have dump from ecu post here meaby anyone can remove this dtcs.
    you are new new newbie in this world not?
