Results 16 to 30 of 44
Thread: XPROG M USAGE
  1. #16
    DK Veteran pirilla's Avatar
    Spain
    I have just received my xprog-m clone and I have a question.
    When I open xProgDesktop and plug xprog via USB, software recognizes COM5 as programmer, but any LED lights in xprog.
    Is this normal?
    I haven't wires to connect it to any device and test and I am impatient!!!!
    Thanks.
  2. #17
    Quote Originally Posted by pirilla View Post
    Is this normal?
    Thanks.
    I will receive mine next week.....what about adaptors???? How much adaptors has? Comes you in a Wallet with all adaptors???
    When receive it I will tell you if mine works like you.
  3. #18
    Is this normal?
    Thanks.
    ONly has usb connection or have also com connection, has you any pic of yours??? I have not seen any pic of connections and adaptors.... Thanks
  4. #19
    obdmaster's Avatar
    Never never land
    Thumbs up
    Is this normal?
    Thanks.
    Yes no leds are lit till you read a device m8
  5. #20
    Spain
    It comes with lots of adaptors, but mine not in a wallet.
    It has RS232 (COM) connection as well as USB. USB connection is only a USB-RS232 bridge.
    Right now I don't have pictures, but tomorrow I can take pics and show you.
    Thank you obdmaster! I feel better now knowing it m8.
  6. #21
    bram380's Avatar
    Indonesia +628153111774
    Quote Originally Posted by almlohe View Post
    hi
    sorry but i dont need data sheet i need file ee (93c46) for xprog m
    omar almlohe
    I've tried to read the EPROM 93c46 with SmarPro x8, but there is no data in it and empty.
    I have try also with MProg 3.5 but still the same, there is no data in it.
    Certainly, authorizations code stored in the ATmega64.
  7. #22
    branco's Avatar
    paris france
    Quote Originally Posted by bram380 View Post
    93C46 is not emty
    maybe atmega erased it
    I will read mine ( 93C46) and send here
    regards
  8. #23
    Spain
    I have been trying to read a device with my new X-Prog-M (clone from obdfactory) but I have some trouble:
    -Programmer didn't come with USB drivers, so my laptop recognize it because I have had installed other USB-Serial converter, but I don't know if drivers are right. I have test in other PC, but I don't have drivers for USB, so I couldn't use USB.
    -When I clic "read" button, no LED lits and no Voltage in supply pins in dip8 socket (i'm trying to read 93c46 serial eprom). Allways appears "Device is silent", but this message appears if X-Prog-M is not connected to serial port, so I'm confused about its meaning...
    Does someone know what's happening???
  9. #24
    obdmaster's Avatar
    Never never land
    Thumbs up
    if using by comport needs external 15vdc power supply m8
  10. #25
    Spain
    I forgot writing it.
    For serial test I have connected 15V external power supply, but same results as USB test.
  11. #26
    branco's Avatar
    paris france
    in environment you must set usb port
    and soft comes with usb drivers
    regards
  12. #27
    Spain
    Quote Originally Posted by branco View Post
    regards
    In environment it recognizes programmer as COM6, like a serial port (pluggin in USB) because windows recognizes it like USB-Serial converter.
    My soft was only one .exe file that installs XProgDesktop.
    Do you have other file with drivers?
  13. #28
    branco's Avatar
    paris france
    use search button friend
    it ishere in forum
    regards
  14. #29
    Spain
    I'm sorry but I can't find drivers seaching the forum. If I search "x-prog-m drivers" only this post appears, and if I search "drivers" thousands of posts....
    Help will be apreciated.
  15. #30
    I think you can use the original one here:
    | AUTO SERVICE "TMT" - XPROG-m downloads |
