It comes with lots of adaptors, but mine not in a wallet.
It has RS232 (COM) connection as well as USB. USB connection is only a USB-RS232 bridge.
Right now I don't have pictures, but tomorrow I can take pics and show you.
Thank you obdmaster! I feel better now knowing it m8.
I've tried to read the EPROM 93c46 with SmarPro x8, but there is no data in it and empty.
I have try also with MProg 3.5 but still the same, there is no data in it.
Certainly, authorizations code stored in the ATmega64.
I have been trying to read a device with my new X-Prog-M (clone from obdfactory) but I have some trouble:
-Programmer didn't come with USB drivers, so my laptop recognize it because I have had installed other USB-Serial converter, but I don't know if drivers are right. I have test in other PC, but I don't have drivers for USB, so I couldn't use USB.
-When I clic "read" button, no LED lits and no Voltage in supply pins in dip8 socket (i'm trying to read 93c46 serial eprom). Allways appears "Device is silent", but this message appears if X-Prog-M is not connected to serial port, so I'm confused about its meaning...
Does someone know what's happening???
I forgot writing it.
For serial test I have connected 15V external power supply, but same results as USB test.
I'm sorry but I can't find drivers seaching the forum. If I search "x-prog-m drivers" only this post appears, and if I search "drivers" thousands of posts....
Help will be apreciated.
I think you can use the original one here:
| AUTO SERVICE "TMT" - XPROG-m downloads |
