Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
Thread: XPROG M USAGE
  1. #31
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Quote Originally Posted by pirilla View Post
    I'm sorry but I can't find drivers seaching the forum. If I search "x-prog-m drivers" only this post appears, and if I search "drivers" thousands of posts....
    Help will be apreciated.
    Tomorrow I'll get back to work and I'll upload full cd mate.
    Whatever seems impossible is just not yet important enough.
  2. #32
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    This is xprog-m driver
  3. #33
    DK Veteran pirilla's Avatar
    Mar 2010
    Spain
    Problem solved.
    Now I can read/write 93C46.
    Tomorrow I will test with MCUs, but obviously programmer is working OK.
    Thank you all !!!!
  4. #34
    Apr 2010
    Quote Originally Posted by locks85 View Post
    Hi, its my first post in this very well setup forum so straight to the subject.
    I just got my original xprog m but unfortunately i didnt find in the box any usefull pictures showing how to use the programer, how to connect it to the turget mcu, actually i bought it just with the bdm adptor for using it to read eeprom from ews4 and cas modules. I know i should have asked the manufacturer for these pictures and informations but the truth is i am so excitet i cant wait. However sooner or later tmt will answer but i do have a spare ews4 in my workshop that i would like to know how to do it yesterday.
    I hope i didnt upset some one with my post.
    Regards
    Marinos
    i use xprog any question please ask
    when you select the device there is connection poton help you to connect this device to xprog
  5. #35
    Nov 2009
    Wirral
    anyone get EWS3 Kline to work? Im struggling, all i get is a flashing green light, and initilising.. iv got 15v power to. Clone btw.
  6. #36
    mexanico1971's Avatar
    portugal
    Hi peaple ! thas anyone knows how to make the connections to 374 , 104 pins to x-prog divice ! and what usb- com shold y put x-prog 1 or 2 because whem i install the soft apears in (com 7) and at baud ! 9600, or mor ?!
    thanks in advanced ?
    regards !
  7. #37
    Feb 2010
    Hi i did one 2L86D in the past, now i am trying my second one and when i press read i get DEVICE SILENT.
    Please help
  8. #38
    Feb 2010
    So i did it, problem was with the drivers, i dont know why but i just had to reinstall them. Remember i am using the original tool just for reference.
    Regards
    locks85
  9. #39
    Nov 2009
    Morocco
    Problem solved.
    Thank you all !!!!
    hi m8.
    can you let me know how are you managed to read 93c46 because i have the same prob with this message device is silent.
    thanks.
  10. #40
    Fallen's Avatar
    Dec 2009
    I had a lot of issues with "device is silent" when reading large MCU's, I was powering it externaly with a 12v 1.5 amp power supply.
    I swapped it to a 19v 3.4amp power supply off my laptop and it worked 100%.
  11. #41
    Jul 2010
    melbourne, australia
    do you do that even when the software says it wants a 15v power supply fallen?
    By the way, I just used your tms370 guide, it was very helpful, so thanks!
  12. #42
    Fallen's Avatar
    Dec 2009
    Mate, I didn't have a 15v power supply handy, I figured a few axtra volts wouldnt hurt right...
    I bet it even made it work faster!
    Glad to help mate.
  13. #43
    Apr 2010
    I have XPROG 4.5 M with Atmega64 damaged how can I copy the ATMEGA64?
    Thanks to all
  14. #44
    DK Veteran gtmech's Avatar
    Jul 2010
    Hell
    Quote Originally Posted by hamza338 View Post
    hi m8.
    thanks.
    Get a UPA Programmer aswell buddy.
    UPA is perfect for 93c46 where as X Prog-m is perfect for other types of chips like 2D47J. The UPA has the adaptor board for the 93C46, just solder it on and plug it in and your done, X Prog is not so easy with the 93c46.
    Its best to always have a UPA and a X Prog-m.
