pin renault from dump - Page 2
Page 2 of 27 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 404
  1. #16
    TeL200's Avatar
    Worcester UK
    Quote Originally Posted by lissbox View Post
    dump uch sagem
    say PIN CODE
    Pin Code: DB6874FACAF3
    Auto Locksmith / Security Professional
  2. #17
    TeL200's Avatar
    Worcester UK
    Quote Originally Posted by jman12 View Post
    Here a dump off my Clio 2 .
    Key is in bad condition so need to overide the im*o
    Could someone please post he required pin (code)
    Thanks in advance
    http://www.jman.co.za/att/clio.rar
    Pin Code: 8958
  3. #18
    PierreTheron's Avatar
    Centurion,South Africa
    Default Uch dump
    Hi need pincode 4 digit.
    Also need code to reprogram new key.
    Pierre
    Renault 2001 clio 2
    Got this one sorted out.
    Fault was wiring between fuse 3 in engine bay to pin 30 on ecu.
    Did not need to use pin..
  4. #19
    Top Poster andresfn18's Avatar
    Mexico D.F.
    Thumbs up
    Your pincode is 6697!!!
  5. #20
    Quote Originally Posted by TeL200 View Post
    HOW FIND PIN CODE FROM THIS DUMP?THERE IS ALGO?
    THANKS
  6. #21
    Default Clio2.dump
    Hi would like to get 4 digit code for this dump
    Thanks in advance.
    Pierre
    Got this one sorted out.. Its a runner.
    Fault was key fob ..I Ihink.
    Re soldered all smds and parts on key.
    Car started first time after this.
    Thanks for help.
  7. #22
    Mexico D.F.
    Thumbs up your ::::
    your pin code is: 6124
  8. #23
    tell me what the password please
    Pass :::::::::::::::::::pincodeclio2 ( for the blind)
    Pls Click thanks button if this is helpfull
    Does not help on uch 3 dump.
  9. #24
    yes i think your rite
  10. #25
    Default Sagem Uch -BG
    I need pin from UCH Dump 93c66.
    Clio 1,2??? 2001
    Thanks in Advance.
    I presume that the 8 bit dump is the correct one.
    I generated a pin and just want to confirm it is right
    Pin FF00FF30FEFF
    Do I need to give more info?
    Clip says it must be uch N2
    PS.Dumps are not correct anyway.
  11. #26
    Not to bother about above post.
    Got vehicle running.
  12. #27
    What is the best machine for to make a dump?
  13. #28
    Quote Originally Posted by isaky View Post
    Depends on what you want to spend.
    I have GQ 4x and UPA Usb.
  14. #29
    Top Poster skona's Avatar
    ON AIR-LANDING
  15. #30
    Mexico D.F.
    Your PinCODE is:
    10 7D DA FA E1 51
