Page 5 of 27 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 404
  1. #61
    Top Poster acaducati's Avatar
    Serbia
    Hi, Can someone tell me code...
  2. #62
    gokey's Avatar
    pin is BD1D983CF5DA
  3. #63
    BIH
    do not have another tool for Reno, clip tells me that"the execution is not satisfactory"
  4. #64
    BIH
    I solved the problem reported kay with Silca sbb without any problems,if anyone knows why this clip did not want to do a tell as
  5. #65
    Quote Originally Posted by pajo View Post
    You used the same pin that you used with the clip?
  6. #66
    Hello
    Please little help
    I have a renault kangoo 1.5dci (Sagem immo with one black and one white conectors) and i need pin code to start the engine with Renault Can Clip in emergency mode to see if the engine is ok (the car stays unmoved for about 1 year) .I read the 93c66 with Willem programmer ,everything ok .When i put the dump in Zedbull tells me "wrong file size" and cannot read the pincode .Also i try to read to another programers , another type of reading , same result . Please help me to know if it the file is it ok ,maybe to calculate the pin . Thanks
  7. #67
    DK Veteran cleevesy's Avatar
    is it a 2002-2007 kango then pin is : 8D 6C ED FF 92 92 hope this helps
  8. #68
    What tool do you use to find the pin ?
  9. #69
    i have abritus key tool.
  10. #70
    BIH
    eiemax
    yes i used same pin
  11. #71
    Feb 2011
    Hi.Please calculate my PIN from dump Clio2 UCH Sagem 93C66
  12. #72
    gokey's Avatar
    pin is " 5E BD 05 FD DE 76
  13. #73
    Feb 2011
    gokey - thanks PIN 100% correct
  14. #74
    The land of choice
    Hello! I need pin from dump, car is Renault Kangoo 1.9 dti, 2001y, BMT Sagem, 93c46.
    Big thanks!
  15. #75
    gokey's Avatar
    not read well
