Results 1 to 10 of 10
    korrni's Avatar
    UE
    Default Mileage adjustment for Lexus IS300H F Sport Display
    Hello, guys,
    Can anyone help me to adjust de mileage to a Lexus IS300H F, eeprom 93A86 inside. The car has 156000km and the customers bought a second hand sport display which has 21000km. I bought the solution for adjusting the mileage from carhexedit, changed the mileage to 156000km, all good, but, when the customer is going with the car, after locking it, the mileage jumps back to 156000km. I will post the original reading and the dump modified which does not work. Can you help me adjust it right? Thanks!
    May 2016
    medellin colombia
    hello, check that all the pins from 93A86 are correctly soldered to the printed one and that you do not have dirt on the ic
    korrni's Avatar
    UE
    Quote Originally Posted by berperez2003 View Post
    Hello and thank you for your answer.
    Actually, I didn't desoldered the eeprom, I used clip in order to read it.
    al70's Avatar
    Nov 2017
    Éire
    or read as 93c66 16bit
    May 2016
    medellin colombia
    try this and report
  6. The Following User Says Thank You to berperez2003 For This Useful Post:
    korrni (11th February, 2022)
    korrni's Avatar
    UE
    try this and report
    Ok then, I will try and report. Thank you!
    korrni's Avatar
    UE
    Quote Originally Posted by al70 View Post
    hello and thanks for your answer. In the sport display dash the e2p is 93A86.
    al70's Avatar
    Nov 2017
    Éire
    Quote Originally Posted by korrni View Post
    sorry, i mean read as 93c86 16bit and post
  10. #9
    korrni's Avatar
    UE
    Sorry for the late answer, here is the reading, but seems identical
  11. #10
    korrni's Avatar
    UE
    try this and report
    Your solution is ok, thank you!!!
