Hello i have here an Audi A4 B8 3.0TDI which begun with an defective BCM2 (Because of wrong trailer module installation)
So i cloned the BCM2, did it for the first time, and by accident i made the "instrument cluster" virgin!
So to made it match again, i needed to get the gataway's eeprom data, so i desoldered eeprom from the gateway and readed it..
After installing the gateway again, the gateway also did not work anymore (must be broken when soldering eeprom back)
I had laying a another gateway around (exact same partnumber) and this time by clip i wrote the data from the old gateway to the new gateway.
Also made the cluster back alive with the gateway eeprom dump.
So all the components are back working again...
But i can not make the car running again....
A lot of faults appear on the dash like ESP, ABS, Airbag, Headlight range defective, TPMS, Parking brake...
And there are a few modules which VCDS can not reach anymore!
- 01 Engine
- 02 Transmission
- 15 Airbag
- 55 Headlight Range
What i think is because of the new BCM2 and the new gateway module, there is a VIN mismatch.. Otherwise i really don't know how this can be solved..
The ECU and transmission are untouched... and have for sure an VIN number.. but they can not be reached anymore...
I have all the backups from the gateway, the BCM2 eeprom and flash, also from the ECU the flash and eeprom...
The tools i have are: ODIS, VCDS, VCP ori, VVDI2, VVDIPROG, Autel IM608.
I checked already all the fuses, and all the relais, they are all good!
Is there anybody who can help me with this, i am a bit lost at the moment....
I have a scan here from VCDS, (i deleted the modules without errors to make it more readable)
And normally when you make an AutoScan, you always see an VINnumber in the filename from the VCDS autoscan.. The VIN is not visible in the filename anymore...
I also uploaded the text files i made with VVDI2 with all the calculations from the ECU and the BCM2
Hopefully somebody can tell me what to do know! Because i really don't know what to do anymore...
Sunday,13,February,2022,02:43:23:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.12.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
www.Ross-Tech.com
Chassis Type: 8T0
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 20 37 42 46 47 52
53 55 56 62 69 6D 72 77
Mileage: 282070km-175270miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AD HW: 8K0 907 379 AD
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 140D00
Shop #: WSC 37417 001 1048576
VCID: 7BA3F7F153E69E03261-802E
No fault code found.
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0140
Revision: A1000000 Serial number: 0115.07.081186
Coding: 36000000
Shop #: WSC 06335 000 00000
VCID: 70B9D0DD0AA0ED5B833-8024
2 Faults Found
01314 - Engine Control Module
008 - Implausible Signal
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 128
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:37:35
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 128
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:37:31
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 C HW: 8K0 920 930 C
Component: KOMBIINSTR. H16 0221
Revision: 00200000 Serial number: 99463GK78
Coding: 0F0F11000B00000C020000
VCID: 2D0709A9DD12C0B3E85-8078
1 Fault Found
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:38:38
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 8T0 907 468 AJ HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0121
Revision: FB402044 Serial number: 4400F087118034
Coding: 000003
VCID: 094F9D39093ABC9324D-805C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 1802E775300608
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Part No SW: 8K0 907 064 AE HW: 8K0 907 064 AE
Component: BCM2 1.1 H71 0145
Revision: 00002001 Serial number: 0113132972
Coding: 01000E20203A3015012002
Shop #: WSC 06335 123 12345
VCID: 73B3DFD17BB6D6437E1-8026
Subsystem 1 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 2 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS221 H06 0037
3 Faults Found
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:38:18
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 0835
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 0852
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14004 Serial number: 34821020070704
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 3FDB43E1077E42234A9-806A
1 Fault Found
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Date: 2064.00.00
Time: 00:02:43
Freeze Frame:
Voltage: 14.10 V
Temperature: 31.0°C
Temperature: 34.0°C
Bin. Bits: 00000100
Bin. Bits: 00000100
Bin. Bits: 00000000
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000175495
Shop #: WSC 00000 000 00000
VCID: 313F15D9C12AA453CCD-8064
4 Faults Found
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 4
Fault Frequency: 4
Reset counter: 128
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:38:38
Freeze Frame:
Voltage: 11.80 V
Count: 67
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 4
Fault Frequency: 2
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 0842
Freeze Frame:
Voltage: 11.80 V
Count: 58
Speed: 0.0 km/h
Hex Value: 0x0270
Hex Value: 0x0001
Hex Value: 0x0101
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:38:23
Freeze Frame:
Voltage: 11.80 V
Count: 66
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Freeze Frame:
Fault Priority: 4
Fault Frequency: 5
Reset counter: 168
Mileage: 282079 km
Time Indication: 0
Date: 2008.02.13
Time: 08:37:40
Freeze Frame:
Voltage: 11.80 V
Count: 64
Speed: 0.0 km/h
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Address 55: Headlight Range
Cannot be reached
