Read BCM and ECM.
Hello House
Anyone has an idea if it is possible to plug n play a lockset for Chevrolet CruzeLS 1.8 2010
If so, what modules should I get.
The ECM is bad and I got another ECM but upon swapping the flashes the car didn't start still and I immo offed and still it don't work. No one near has proper tools to program it.
Read BCM and ECM.
IMMODATA ACDelco EXX<=>BCM / DTC off + CRC ... Opel Delco HSFI 2.X , HSFI-C , MT35E
Qenzo (17th February, 2022)
Read files from BCM and ECM share here. What ECM?
Thank you
I will share the files tomorrow.
Hi Filutek, the file from BCM is here.
The engine is 1,8 with these park numbers
GM 25181280
5WY1H12A
76.1
This is the BCM data, The ECM data is corrupt
The ECU is dead so the car won't start, I found another ECU and swapped the flashes, still it didnt work, I immo offed the donor ECU and I got the B0389A FAULT which was about Environment Identification.
On searching about that I learnt GM discourages swapping of modules, so that is why I thought to get a lockset and wanted to know what modules I should buy and whether it is plug n play or need programming.
However if you can guide me to solving this I appreciate in advance.
Mileage show and radio still plays.
The ECU flash is corrupt, the data doesn't make sense in there
Send here the original readings from both ECMs without changing to immo off.
I will tomorrow, though they are the ones I say are corrupted,
Thanks for your patience
Hello Filutek
I wasn't able to get the corrupt flash data and the original read of donor ECM, the guy who helped me read lost them.
At the moment I have a virgin file for the flash, was hoping to write it in the donor ECM and take it from there, though am not sure what the process will be. Please advise of the process to take with the virgin file.
Alternatively I just got KTAG so I thought cloning the original ECM but since the flash is dead, I will only write processor data.
