OKI M851G EPROM 8PIN SMD .
read as 93c46
cj
Cool photo, nice to see after a crap day. (Only managed to chip some paint of the wing of a Rover - no other damage - in a whole day!)
*THINK* you best pop here, bottom of the page (ish)
Lockdecoders Eeprom functions
Two to look at - sorry - can't help more
read as 93c46
cj
ADEL.KSHLAF (21st January, 2018)
No, the immo information is in the BIG chip. If you start the car or try to start the car with the red key, probably you have damage definitevely the IMMO ECU.
To verify if the IMMO ECU is damaged, install the IMMO ECU in the car and turn the ignition to ON, and tell me if the IMMO ligth blink or not or is allways on, then remove the key and tell me again about the IMMO ligth. Test the red key and the 2 black keys and tell me the result.
If the IMMO ECU is damaged you have this solution: find near you a used IMMO ECU VALEO (not Megamos) with almost 1 black key. The transponder is a id:33 easy to clone in any equipment. Cut a new key, install the used ECU in the car and clone the transponder for the used ECU and you have the car working.
Best regards,
AutoCrypto
the immobiliser light blinks rapidly with the red key in the car but still it wont program it ive tried all the methods available this is the only way left
as for a new immo ecu i was going to buy a unit on its own and clone the transponder into this key but the problem is my local breakers wont split it they want to sell the complete set including lock sets,ignition barrel,ecu,immobiliser ecu as they wont sell the immobiliser unit on its own
so your saying its the big chip and cjawahir is saying its the 8 pin one so which one is it guys?
The immo information is in the BIG chip.
You have the IMMO ECU damaged. In a good IMMO ECU, when you turn the ignition on with the red key the immo light lights during 2 seconds and goes off. When you remove the red key the immo light blink during 5 seconds and goes off.
Your IMMO ECU is damaged you cannot program keys or make new keys by ECU dump. Try the ECU dum is for lose your time.
You need to find a used IMMO ECU. You dont need the keys, you only need to clone the transponders. You can return the keys after cloning the transponder.
Good luck.
Best regards,
AutoCrypto
thanks i will try this so just the immobiliser box and one key to clone nothing else? car should start fine if so i may have persuaded someone to give me an immobiliser box and key
Hi peolple,
I've this 99 Civic all keys lost.
Disassembled immo box (like the one posted by JIMMYQ) and read HC05 with XprogM. Produced transponder, but data on transponder didn't seemed ok to me. Too much FFFs on the beginning. Anyway... I re-assembeled it on the car.
However, immo light don't even goes on and car doesn't cranck at all!! I thought that 1/2 tracks going to the HC05 might not be perfectelly ok and I've swaped HC05 to another second hand Valeo immo box and it's the same... shall I swap the other eprom of the immo box? The small one, 8 legs?
Also one thing that happened with the original immo box was that, once assembled, the immo light was always on (but faint...). Even without key in the ignition. And the car crancked but not started. I've checked the soldering and since then no light at all as described.
Please give me your thoughts!
Thank you SO MUCH,
PM.
How bizzare only just over 2 hrs ago a costomer handed me one of thrm valeo units told him to naff orf i'll use one in stock.
sadly unable to tell if this will work as got one but not a car!
Blank the oki chip in ecu then get off ebay " yamaha immo emulator"
?10 delivered. The pulse from each TO THE NAKED EYE look the same so might work
Did you read eeprom only or flash in hc05?
psam (6th April, 2013)
Thank you ma friend!
In fact I don't really want to do immo off. Just as last last option... The car was running and I don't want to be responsible for that.
What do you mean by NAKED EYE?? Sorry but I didn't quite understood...
I've only read the HC05? Do you think that I should?
Thank YOU again.
Working honda led test light FLASH FLASH FLASH FLASH
YAmaha emulator. FLASH FLASH FLASH FLASH
working renualt FLASSSH FLASH FLASSSH FLASH
Reanult emulator FLASSSH FLASH FLASSSH FLASH
if that makes sense would have been able to tell you but i have a tawt for a boss
psam (7th April, 2013)
I see what you mean.
But, since I've this used immo box (no keys), can't something be done with it?
Shall I try to produce transponders from it?
When I produced trasnponders from the original immo box, I used both ZB clone and AVDI ori.
ZB recognized the bin ok, and gave me info to produce transponder ready to start the car.
AVDI give me info to produce Key 0 and Key 1.
Since they don't give any info about red or black key, in your opinion, they intend to produce black keys? Or the ZB gives me red key to program the black ones?
Please advise people.
I'm really stucked on this one.
Thank you SO MUCH.
dont know on the black/red key things
Not being rude or anything but i think you have buggered the HC05 - see if you can LEECH another dump off here - then load that to your box
did you short out the xtal on the board?
You have a few options
1) F**K it off to Mr Yip at the dealers knowing it will come back with a bill for
?2500 and told "We can't fix it new parts only"
2) Find a scrap yard get a matching ecu immo box and ecu fit and
stuff the scrap yard key behind the dashboard
3) Fill engine ecu with FF (do that anyway) OKI chip on daughter board
you need a 'solder pad' adaptor to read as slightly bigger than 93C46
then try a yamaha emulator - like a Spar shop - was so close yet so far to doing that experiment for educational or entertainment purposes only.
a RENUALT emulator does NOT work.
Where are you in the world? I'm in Meat-City between London and Scotland - would *LOVE* to help you off-line on this one, but bet your a million miles away.
psam (8th April, 2013)
Yup... I'm thinking that too... perhaps Xprog didn't handeled the HC05 very well... perhaps it's scre...
Anyway I still have a "virgin" (not so virgin as it was already used before...) immo box.
What do you think if I produce transponders for this one and put it on the car?
In fact not a million miles away but a couple of thousond...
I'm from PT. But thanks anyway my friend. As you can figure any help it's MUCH APRECCIATED.
Thanks again. Sorry for bothering so much. Rookies are like this... a pain in the ass... eh eh eh...
By the way... what do you mean by shorting the xtal?
Thanks.
