can you help me to edit mileage from a VW golf with edc17c64 ecu?
(please only if you have good solution.... i don't have the car to test....)
ori : 265724
and need : 145724
Thank you...
ori : 265724
and need : 145724
Thank you...
Neo8 software has a good solution for these
If i Helped you,use thanks and rep button to thank me back
km's* 1000 to inverted hex (**) 9E D4 0F a few instances .. 4 ish ..
(using Brain.exe software)![]()
Panathaole (18th February, 2022)
And checksums must be correctedNEO 8 is a quite expensive software. I've never seen cracked versions of NEO
Please try and report!
Rgs H2Deetoo
I think the most important areas are modified (f.e. those which you can read back), but please tell me where so we can discuss it ...
Working hours should be changed too!
Working hours is new to me. Someone care to show an example of changed working hours?
Yes you are right, that's a new record type for me.
Ok, corrected now.
And yes if you connect power, ignition and canbus then you should be able to talk to ecu to check the mileage values.
Rgs H2Deetoo
