Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Default VW GOLF EDC17C64 MILEAGE
    can you help me to edit mileage from a VW golf with edc17c64 ecu?
    (please only if you have good solution.... i don't have the car to test....)
    ori : 265724
    and need : 145724
    Thank you...
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Neo8 software has a good solution for these
    If i Helped you,use thanks and rep button to thank me back
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by Stelaras26 View Post
    Have you test it?
    Moderator
    PremierD's Avatar
    Jun 2009
    km's* 1000 to inverted hex (**) 9E D4 0F ​ a few instances .. 4 ish ..
    (using Brain.exe software)
  5. The Following User Says Thank You to PremierD For This Useful Post:
    Panathaole (18th February, 2022)
  6. #5
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by PremierD View Post
    Thats all???
    Unfortunately i don't have the car to test......
  7. #6
    Smart66's Avatar
    Dec 2020
    And checksums must be corrected NEO 8 is a quite expensive software. I've never seen cracked versions of NEO
  8. #7
    Oct 2014
    Netherlands
    Please try and report!
    Rgs H2Deetoo
  9. #8
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i see 265592......
    they give me 265724........ only that's strings edit is enough? (as i say i don't have the car to test...)
  10. #9
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by H2Deetoo View Post
    Rgs H2Deetoo
    Hi thanks....
    i think your dump is not fully edited..... i see in more places the km....
  11. #10
    Oct 2014
    Netherlands
    I think the most important areas are modified (f.e. those which you can read back), but please tell me where so we can discuss it ...
  12. #11
    Smart66's Avatar
    Dec 2020
    Working hours should be changed too!
  13. #12
    Oct 2014
    Netherlands
    Working hours is new to me. Someone care to show an example of changed working hours?
  14. #13
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    You can find one more repeat at 9540......
    can i use the same pinout to connect it with diagnosis on bench to check the mileage after the edit? (no the gpt0,1)
  15. #14
    Oct 2014
    Netherlands
    Yes you are right, that's a new record type for me.
    Ok, corrected now.
    And yes if you connect power, ignition and canbus then you should be able to talk to ecu to check the mileage values.
    Rgs H2Deetoo
  16. #15
    honingkoning's Avatar
    Jun 2010
    Dessert
    How to check milleage with vcds
