I have 2009 E350 W212 look like CGW boot mode get problem pleas help . i can communicate only with CGW module check engine on fan on ,Tried remove battery for the 24 hrs no luck
Pleas help.......
Pleas help.......
Eep status boot and flash corrupted .
Hi. i need to fix it pleas
I read eeprom and flash with by Abrites OBD . cgw part #2125451001
Can wee try to repair eeprom / may be will work ?
You need programmer to write flash. it can be xprog or some like this. EEP you can write with FVDI
For what this playing , like eeprom obd and flash bdm.
If eep stay in boot and flash corrupted , in here noting to do any more with obd2.
For put to work cgw to normal mode all job only bdm .
If not , so.......my option better don't touch any more this car if you don't want anderstand programming world.
Min2xx (20th February, 2022)
Ok i got it pleas look 3m25j
Hi. Works perfect ..............Thank you very mach
