    Dec 2021
    Default Fiat Uno map access - IAW59FB ECU
    Hello guys,
    I am looking for a way to access the original map of my Fiat Uno 1.0 2001 (ECU: Magneti Marelli IAW59FB).
    It doesn't have an OBDII port, but it have a 3-pin diagnosis port connector:
    Is there a way to use a MPPS/Galletto directly on this port by wiring the pins or the only way is to entering in boot mode and use Galletto directly on it?
    Thanks!
    Dec 2018
    Hi. Where do you have the ori number from the ecu of the car?
    Dec 2021
    Quote Originally Posted by elektronik325 View Post
    Actually, I do not know how to access the ECU to get the .ori file.
    The only info I have is what is displayed on a sticker on my ECU:
    *IAW 59 FB.UN
    *SW 3600/27M
    Dec 2018
    Upload a photo Ecu. Iaw 59 was in hundreds of Fiats. Describe what you have a problem with the car? It's not about communication. But the problem with the tsar
    Dec 2021
    Oh... no problems with my ECU. I am learning about chiptuning and since I got some cars here, I want to practice on it.
    See the ECU photo attached.
    Feb 2014
    Spain
    Hello
    Maybe you need an obd2 Fiat adaptor:
    Pin 2 is ground
    Pin 3 is K-line
