Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    DK Veteran cristec's Avatar
    Sep 2009
    Essex, UK
    Hi PremierD, When I saw the name Tam on the CDH forum I thought it might be you.
    Yes I have had CDH gear for about 15 years , the first interface i had had a sine wave generator for doing the early Philips radio's with ER1400.
    I do not use it very often, now and every time I do I have to remove the token and then re-install the software.
    Last time I tried it would not re-install, and so I am sending it back for later software to be added.
    Thanks for the info on the 93c46.
    Semper in Excreta
  2. #17
    Apr 2010
    Default Clarion 93C46
    I have just read a 93C46 from a Clarion PU-2294A and the device did have the rotated pin out.
    Read with a LV48 programmer
  3. #18
    Dec 2009
    http://www.digital-kaos.co.uk/forums...-1562-a-93087/
    forum search clarion rotadet 93c46 ..
  4. #19
    Mar 2010
    UK
    Hope u got it sorted Cristec.
    P.s. Another cdh man here
  5. #20
    Apr 2010
    93c46 chips with rotated pins have a T in the code after part no
    eg TEM8
    T = Rotated
    E = Temp Range ( -40 - +85)
    M8 = Package type (SO)
  6. #21
    Hayssam1's Avatar
    Nov 2009
    Germany
    HALLO...
    the fairchild 93c46 is a 8 pin smd soic device with rotated pins, i have found a data sheet on it here
    http://www.meditronik.com.pl/doc/plus/93c46.pdf
