i need also.
i need also.
Non problem. Nexiq fully supported Cat Et.
hello ,
me too , but the best price i found is for 750 $ ...
i have 1 unit
it is USB-Wireless
NEW (not used)
anyone interested can contact me
not using it, need to sell it,
TOOL TOPIA.COM HAS THE NEXIQ PLUG WITH THE 6 AND 9 PIN FOR $685 THAT WAS THE CHEAPEST I COULD FIND IT AND THEY HAVE FREE SHIPPING IN THE US
hi there, from what I have heard using the nexiq usb adapter, there are problems with trying to regen or run a data log, due to the fact that is does not use a dual data link like the cat com II, could any one verify this?
At work I always use the CatCom II , and have not had too much experience with the Nexiq adapter.
I do however want to buy one since it will work with everything such as cummins, cat, allison, bendix, and the list goes on from what i have heard.
de nexiq is only for trucks , for cat machinery use original adapter caterpillar
Hello guys, I'm wondering if the software for meritor transmissions "TransSoft" can be supported by Nexiq USB-BT Link J1708?
If USB link drivers are installed, the nexiq will work in dual data link with CAT ET. With ET open go to 'UTILITIES' then 'PREFERENCES' then 'COMMUNITCATIONS' from the drop down menu pick 'RP1210 DEVICE' check off 'ENABLE DUAL DATA LINK SERVICE'.
Now most important, in the same window click the 'ADVANCED' box and now pick ****USB-link-NEXIQ Technologies USB -Link****** from the drop down menu.
If your laptop is bluetooth you can configure it for that too if you want but there is much more to the set up.
As for the cummins program it does not ask for dual data.
I use the USB link for both Cat and Cummins and have performed regens with them both.
tony thanks that is what I wanted to hear, cat and cummins is what I need it to work for, already have a cummins inline 5, but really want to get the nexiq, will work for everything I want.
NEXİQ adapter. Do we have the chance to connect with the Cummins engine? or what do I connect to the engine
yeah u can ...only need to know the engine brand ...and communicacion protocol.
nexiq ,dearborn,noregon....covers all americans engines..also some european volvo?s and renault.
I hope that be usefulle for u.
thk you HERCAMP
