Results 1 to 3 of 3
    Aug 2016
    Default Lost ABS coding for 2011 Seat Ibiza 6J
    Hi guys
    I need abs coding for a 2011 Seat Ibiza.
    I was repairing various clusters, and I put the wrong one into this car like an idiot... From now on every VAG car I get into I will start with a scan...
    Its a 2011 Seat Ibiza Estate
    Auto Gearbox
    UK RHD model
    No TPMS
    I dont think it has Hillstart
    No Stop/start
    VIN: VSSZZZ6JZCR040445
    Engine (J623-CBZB)
    Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
    Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
    Component: ABS8.2 front H03 0001
    Revision: --------
    Coding: 000000000000000000000000000000000000
    Shop #: WSC 04941 000 00000
    VCID: 000F350797030A4F99-8054
    Full Scan included
    Thanks so much in advance
    Apr 2021
    Don't worry. Check your PM box, your coding is in there. This abs type does not need as much information as you posted (like gearbox, hill hold, steering position), because it is a pretty simple system with ABS only. But it is nice that you took care of it and posted scan.
    If you run into cases like that more often or are working on cases like this more often I think I can help you solving this yourself.
    Dec 2021
    scotland
    hi there i have same problem on mine
    Monday,08,March,2021,12:20:02:39744
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.12.0.1 (x64)
    Data version: 20201125 DS322.1
    www.Ross-Tech.com
    VIN: VSSZZZ6JZDR076418 License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    4B-Multifunc. Module -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 LE HW: 03L 906 023 Q
    Component: R4 1.6l TDI H33 9979
    Revision: --H33--- Serial number:
    Coding: 00114016000500080000
    Shop #: WSC 131071 1023 2097151
    ASAM Dataset: EV_ECM61TDI02103L906023LE 003012
    ROD: N/A
    VCID: 74E00792DF206F2416-8020
    No ASAM data for: "EV_ECM61TDI02103L906023LE" (VW36 *)
    No fault code found.
    Readiness: 0 0 0 0 0
    Revision: --------
    VCID: 00085B429798438402-8054
    3 Faults Found
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 49
    Reset counter: 208
    Mileage: 149088 km
    Time Indication: 0
    Date: 2031.14.00
    Time: 01:21:24
    Freeze Frame:
    Hex Value: 0x4005
    Hex Value: 0x0000
    Hex Value: 0x3213
    Hex Value: 0x148C
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7F00
    Hex Value: 0x0000
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 245
    Mileage: 148534 km
    Time Indication: 0
    Date: 2029.14.21
    Time: 12:29:53
    Freeze Frame:
    Hex Value: 0x0005
    Hex Value: 0x0000
    Hex Value: 0x12B1
    Hex Value: 0x078D
    Hex Value: 0x00FF
    Hex Value: 0x007F
    Hex Value: 0x7F00
    Hex Value: 0x0000
    00283 - ABS Wheel Speed Sensor; Front Left (G47)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 245
    Mileage: 149088 km
    Time Indication: 0
    Date: 2031.14.00
    Time: 01:21:44
    Freeze Frame:
    Hex Value: 0x0001
    Hex Value: 0x0000
    Hex Value: 0x1231
    Hex Value: 0x06B8
    Hex Value: 0x0CFF
    Hex Value: 0x007F
    Hex Value: 0x830A
    Hex Value: 0x0A0A
    Address 04: Steering Angle (G085) Labels:* None
    Part No SW: 6R0 959 654 HW: 6R0 959 654
    Component: LENKW.SENSOR H06 0060
    Serial number: 090465LG5000PO
    Coding: 01
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_LWSKLOVW25X 005001
    ROD: EV_LWSKLOVW25X.rod
    VCID: 7EF425BAE16C357470-802A
    1 Fault Found
    1140738 - Steering angle sensor
    B1168 54 [009] - Missing Calibration / Basic Setting
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 205
    Mileage: 149117 km
    Date: 2095.14.08
    Time: 05:32:33
    Voltage terminal 15: 14.00 V
    Voltage terminal 30: 14.05 V
    Terminal 15 status: On
    Address 08: Auto HVAC Labels: None
    Part No SW: 6J0 820 045 A HW: 6J0 820 045 A
    Component: J301 Klimaanlage 0330
    Revision: 00 26 08 Serial number: 0000002535374-
    Shop #: WSC 06402 785 00200
    VCID: 244037D2E740BFA446-8070
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 K HW: 6R0 937 087
    Component: BCM PQ25 H+4 H46 0254
    Revision: BF046001 Serial number: 0434 174121321
    Coding: 24882DE8A861250092200EF06C4B8CC80000422F6088000020 0000000000
    Shop #: WSC 64564 324 38760
    VCID: 45868A56CC3AA6AC71-8010
    Subsystem 1 - Part No SW: 6R0 959 802 M HW: 6R0 959 802 M
    Component: J386__TSG_FT 002 3130
    Serial number: --------------------
    Coding: 030000
    Subsystem 2 - Part No SW: 6R0 959 801 P HW: 6R0 959 801 P
    Component: J387__TSG_BT 002 3130
    Coding: 020000
    Subsystem 3 - Part No: 1K8 951 171 A
    Component: DWA-Sensor 00 001 0103
    Coding: 000000
    Subsystem 4 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Coding: 000000
    Subsystem 5 - Part No: 1K8 951 171 A
    Coding: 000000
    6 Faults Found
    01758 - Bulbs for Brake Lamps
    006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00100110
    Fault Priority: 2
    Fault Frequency: 18
    Reset counter: 248
    Mileage: 149126 km
    Time Indication: 0
    Date: 2031.14.11
    Time: 05:19:16
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 21
    Reset counter: 208
    Mileage: 149117 km
    Time Indication: 0
    Date: 2031.14.08
    Time: 05:32:15
    03431 - Activation of Left Parking Light
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 159
    Reset counter: 248
    Mileage: 149117 km
    Time Indication: 0
    Date: 2031.14.08
    Time: 05:35:01
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 155
    Reset counter: 208
    Mileage: 149117 km
    Time Indication: 0
    Date: 2031.14.08
    Time: 05:32:15
    03432 - Activation of Right Parking Light
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 158
    Reset counter: 248
    Mileage: 149117 km
    Time Indication: 0
    Date: 2031.14.08
    Time: 05:35:01
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 154
    Reset counter: 208
    Mileage: 149117 km
    Time Indication: 0
    Date: 2031.14.08
    Time: 05:32:15
    Address 15: Airbags (J234) Labels: Redir Fail!
    Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
    Component: VW10AirbagA05 H10 0020
    Revision: -------- Serial number: 003GX01ABZCZ
    Coding: 003035
    Shop #: WSC 06401 785 00200
    ASAM Dataset: EV_AirbaVW10PBAVW250 A01001
    ROD: N/A
    VCID: 4A9CB96AED2449D49C-801E
    Subsystem 1 - Serial number: 3495RRB400Q4UJ4O88TR
    Subsystem 2 - Serial number: 3505RRB400C4UI5EOOVT
    No ASAM data for: "EV_AirbaVW10PBAVW250" (SE25)
    1 Fault Found
    9447187 - ROD - Unknown Error Code
    - 00 [136]
    MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 149117 km
    Date: 2095.14.08
    Time: 05:32:09
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway
    Cannot be reached
    Address 25: Immobilizer (J334) Labels:* Redir Fail!
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H04 0508
    Serial number:
    Coding: 000000
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
    ROD: EV_Immo_UDS_VDD_RM09_VW23.rod
    VCID: 6ADC19EA8DE4A9D4BC-803E
    Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 C
    Component: LenkhilfeTRW V278
    Coding: 11251
    Shop #: WSC 31414
    VCID: 3068CB82F7B81304B2-8064
    Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
    Part No: 6J0 959 441
    Component: MF-Modul 0007 0001
    Coding: 0000001
    Shop #: WSC 77005 000 00000
    VCID: 70E80B8263385304F2-8024
    Address 56: Radio
    Cannot be reached
    End-------------------------(Elapsed Time: 03:00)--------------------------
    can you help me to find it please . thanks
