Results 1 to 15 of 15
    Sep 2015
    Cool TOYOTA immo off solution for all cars with immo box 4D transponder
    Hi mates. I just learned i new way of making immo off on all toyota cars with immobox that takes 4d transponder. Any. Even with H, G or simple 4d67 or 68 transponder. Universal solution with just a 5 min work. Tested on many many cars. Hilux d4d all, avensis, prado etc.
    Please remember, it will not work on cars with immo on ecu or with 4c transponder.
    Make sure to remove immobox.
    Its all in one solution
    Will not post any password. Just wanna help so if you press thanks and rep i will be fine.
    Will give the solution after the first 100 thanks
    Its a guaranteed solution
  2. The Following 31 Users Say Thank You to raheem1983 For This Useful Post:
    Akamsaeedali (9th March, 2022), Alaa Alshawafi (5th January, 2023), bangreno (7th December, 2022), compact (9th March, 2022), credoline (8th March, 2022), danielif (9th March, 2022), daniersms (8th March, 2022), darrenhyland (14th June, 2022), deliaga (24th May, 2024), Duwagemadusanka (10th February, 2023), Gammoudi (8th March, 2022), gege974 (30th May, 2022), hussin (8th March, 2022), IMM0killer (8th March, 2022), irwin88 (16th April, 2022), jattal786 (10th March, 2022), just4upal (9th March, 2022), KEYTH (10th March, 2022), krisdiv (9th March, 2022), lupu_sandu (10th March, 2022), m-o-y (8th March, 2022), miloudmess (1st April, 2022), muzzz (9th March, 2023), NBAUTO (21st March, 2022), Nee 633 (14th June, 2024), ngakson2002 (8th March, 2022), ostrowpawelprac (8th March, 2022), pepepe2000 (9th March, 2022), rokibar (9th March, 2022), s qubiak (8th March, 2022), vitakot (8th March, 2022)
  3. #2
    ray-ray's Avatar
    Nov 2009
    Thanks,Thanks,Thanks,Thanks,thanks,thanks,Thanks,T hanks,Thanks,Thanks,Thanks,Thanks,Thanks,Thanks,Th anks,Thanks,Thanks,Thanks,Thanks,Thanks,Thanks,Tha nks,Thanks,Thanks,Thanks,Thanks,Thanks,Thanks,than ks,thanks,thanks,thanks, thanks..
  4. The Following User Says Thank You to ray-ray For This Useful Post:
    volodin69 (10th April, 2022)
  5. #3
    Jun 2010
    What happen If it is not enough thanks????????
  6. #4
    Apr 2019
    Quote Originally Posted by ray-ray View Post
    Haha.., thats not enough 100 thanks @ray-ray
    Sent from my vivo 1918 using Tapatalk
  7. #5
    Apr 2014
    Spain
    NEED PASSWORD ? PRESS THANKS AND ADD REPUTATION
  8. #6
    Sep 2015
    Ok Mates... I will not wait for the 100 thanks. But keep pressing thank button for others.
    The solution is simple.
    Find an ic eeprom on old ecu from toyota. Even broken ones the ic comes with number 277 on top.
    I dont know the configuration of it. But it does the miracle. Take that ic from any old ecu and replace the eeprom on the ecu you want to do immo off 93cxx or RAxx or some ecu comes with RHxx and go start the car. Remember to take out immobox
    I tested on many cars.
    Test and report
  9. #7
    YCFYCF's Avatar
    Nov 2019
    SL
    I can’t type 100 thanks .. so I give u this .. will give u much thx as long as u watch it… haaaa ha
  10. #8
    Mar 2015
    Thank you sir
  11. #9
    Sep 2015
    Has anyone tested? Post the results. Im sure it did work
  12. #10
    Dec 2009
    Hello Mate,
    Tested on the ECU 93C56, picture attached and did not work.
    Best regards
  13. #11
    credoline's Avatar
    Србија
    The most stupid thing i'm ever see. 277 IC have + power supply (5v if you are lucky) on pin 8 and pin 4 is GND. All (standard pinout) microwire 93Cxx eeproms have GND on pin 5. Pin 4 is Serial Data Output. You will connect SO pin to some IC pin which is used for GND? How stupid this can be ?
    Quote Originally Posted by raheem1983 View Post
    Test and report
  14. The Following User Says Thank You to credoline For This Useful Post:
    jomberykaso (22nd March, 2022)
  15. #12
    Sep 2015
    Default Tested again
    There others that tested this solution and it worked. How stupid it is??? Well that i really dont know. How it works, i also dont know. But it does work.
  16. The Following User Says Thank You to raheem1983 For This Useful Post:
  17. #13
    Sep 2016
    Hello team,
    I have also been introduced to a universal immo off IC and have successfully tested it on a toyota Vits 2009 model.
    Yes I did my checks and it's an amplifier IC but it sure does work.
    Anyone can try and also let us know the feedback
    IJRCI
    6233C.
    Knowledge sharing
    Sent from my Infinix X6835B using Tapatalk
  18. #14
    Jul 2020
    Hello,
    Thank-you, but on smart keys, how much wiring needs to be done for the button to work as you wrote on another forum?
  19. #15
    Feb 2024
    thanks,thanks,thanks,thanks,thanks,thanks,thanks,t hanks,thanks,thanks,thanks,thanks,thanks,thanks,th anks,thanks,thanks,thanks,thanks,thanks,thanks,tha nks,thanks,thanks,thanks,thanks,thanks,thanks,than ks,thanks,thanks,thanks,thanks,thanks,thanks
