Results 1 to 5 of 5
    Dec 2021
    Default Can anyone check this file if it's good?
    BMW 320d
    EDC16C1
    Can you check it? It has Stage 1, EGR off and hardcut.
    Jun 2021
    Not bad, but you can increase torque in torque limiter gear 3 to 400 from 330 and maybe too much boost for stock turbo. You can set lambda to 17 in afr by MAP and 17 from 1500rpm and 650mg/cycle in afr by MAF. At E6B42 you have limiter temp vs speed you can increase to 100% in 114*C
    Dec 2021
    Can you correct it? If so, how much €?
    Jun 2021
    Here you go hit thx if helped
  5. The Following User Says Thank You to skiera For This Useful Post:
    filipenoiu12 (10th March, 2022)
    Dec 2021
    Quote Originally Posted by skiera View Post
    Thank you so much!
